steering wheel vibration?
Old Apr 29, 2011 | 09:59 PM
stx4x4's Avatar
stx4x4
have a 04 stx f-150 4x4, had the front springs chaged, shocks and struts! now when im driving at either 43mph or 53 mph, i get vibration in steering wheel.....any one have any ideas?? thanks
Old Apr 30, 2011 | 06:11 AM
MCDavis's Avatar
MCDavis
Have you had your tires balanced lately? Could be as simple as a wheel weight issue. It could also be that your lug nuts are improperly torqued (too tight can cause the same feeling as not tight enough).
Old May 3, 2011 | 09:11 PM
keisha9's Avatar
keisha9
i have the same problem except for i have brand new shocks, rotors, pads, tires and wheels, balanced and alignment ..im kind of pissed although i am getting ready to do the sway bar end links and lower ball joints possibly the uppers too. hopefully it helps, good luck . I heard our f150s do this normally but i refuse to believe that
Old May 3, 2011 | 09:16 PM
keisha9's Avatar
keisha9
Old May 5, 2011 | 11:27 AM
1Aauto's Avatar
1Aauto
Former Vendor
Check the inner and outer tie rods, and also the sway bar end links. If any of these are worn or frozen,it could cause a vibration in the wheel.
Old May 9, 2011 | 02:36 PM
1saxman's Avatar
1saxman
More than 90% of the time, it's tire/wheel related. Rotate/balance wheels and see if that helps. Depending on the history of the tires, they may have to be replaced. Check wheels for runout/out of round.
Old May 9, 2011 | 09:47 PM
1bad67sbf's Avatar
1bad67sbf
+1 rotate them and see what happens, if it stops rebalance the ones you had up front.
eds2006stx
Jan 18, 2022 10:54 AM
00GT
Escape & Escape Hybrid
Jul 25, 2010 09:32 PM
sssilvernblack
Nov 4, 2007 08:01 AM
rgf150
2004 - 2008 F150
Dec 26, 2005 01:02 PM
