EGR removal
Old Apr 29, 2011 | 03:35 PM
snakeman's Avatar
snakeman
EGR removal
Does anyone on here know how to remove the air pump and EGR system on a 1994 F350 460 and all needs to be done to the engine?
Old Apr 29, 2011 | 08:43 PM
glovemeister's Avatar
glovemeister
Besides pulling everything, I highly suspect that you will need to re tune your computer to reflect not having an egr.
Old May 8, 2011 | 05:00 AM
Iversen-fords's Avatar
Iversen-fords
I suggest not to get rid of the egr. I was told you could possibly burn up a cylinder but...... the air injection is a kind of simple removal. The biggest problem is plugging the lines to the manifold for the air injection. this also means you have to remove the the cat or plug the port to the cat. another problem is trying to remove the some of the lines from the engine like the one running around the back side of the engine. they are kind of pain. work with it and you'll get it
workforBeaver
Oct 8, 2010 08:13 PM
Petiboy
Aerostar
Nov 5, 2003 02:55 PM
slikness
Dec 19, 2002 10:21 PM
dpoelstra
Oct 25, 2002 08:31 PM
bluemustang
Jun 10, 2002 12:08 PM
