Update
Old Apr 29, 2011 | 10:11 AM
1bad04's Avatar
1bad04
Update
Took my truck in for a complete diagnostics. Did the balance test on injectors and they test good. but what they did find is that my oil cooler is really clogged with a spread of 30 degrease. I know this is really bad and needs to be addressed fast. But is this cause of my low power condition I have been having? I havent had any white smoke or any coolant lose. Have I done any internal damage to my engine?
Old Apr 29, 2011 | 10:18 AM
rdunagan's Avatar
rdunagan
dont know about internal damage id say your fine but id change it out now!!!! before the thing ruptures and then you have a mess on your hands like i did. could be but im thinkin loss of power is somewhere else. techs might know the answer to that but change the oil cooler now!
Old Apr 29, 2011 | 11:22 AM
npccpartsman's Avatar
npccpartsman
I'm wondering if you're not getting a PCM mandated defuel/derate because of the high temp spread. I doubt you've done any internal engine damage, but I wouldn't drive it anymore than absolutely necessary until it's repaired. What's your highest EOT?
Old Apr 29, 2011 | 08:18 PM
Dieselpop's Avatar
Dieselpop
I'm with npccpartsman it is defueling to save itself and when you change the oil cooler you must change the egr cooler.
pop
Old Apr 30, 2011 | 06:59 AM
1bad04's Avatar
1bad04
Thanks guy you's are the best! finally getting to the bottom of this problem will be such a relief. Would It be defueling from the time you start the truck when engine/oil temp is this cold? because Im have the the problem from the time the truck is started. doesnt matter what temp is.
Old Apr 30, 2011 | 07:11 AM
cheezit's Avatar
cheezit
it should not be doing this from a cold engine.
Old Apr 30, 2011 | 07:55 AM
npccpartsman
Have you checked your fuel pressure/filters, etc?
Old Apr 30, 2011 | 08:55 AM
1bad04's Avatar
1bad04
Fuel Filter, (Yes) Fuel Pressure, (No) I have done the blue spring upgrade about 2 mouth ago. Come to think of it that probably around the same time truck started running bad. Is there anything I could have done wrong when changing the spring? Seem to be pretty straight forward took old spring out, put new spring in. Did i miss something?
Old Apr 30, 2011 | 09:12 AM
npccpartsman
It's possible the poppet isn't seated correctly or that your fuel pump is simply failing. Fuel pressure verification is imperative IMHO.
Old Apr 30, 2011 | 09:35 AM
1bad04's Avatar
1bad04
What parts do i need to tap into the regulator to check fuel pressure?
Old Apr 30, 2011 | 09:44 AM
npccpartsman
Something similar to this: 6.0L Fuel Pressure Adapter
The threaded port in the secondary filter housing is an M12x1.5 o-ring thread. It needs to adapt to a 1/8" NPT thread for a gauge or sending unit. Also, try glowshift for a fuel pressure gauge which needs to be 100 psi. Heard lots of good things about them and very reasonably priced. The hardest thing is finding the adapter. You might try a hydraulic store/shop if you have one close by. They might be able to make a one piece hose.
Old Apr 30, 2011 | 08:44 PM
Dieselpop's Avatar
Dieselpop
This may help
Install Pictures
and this
Fuel Spring Upgrade - Windows Live
pop
Old May 1, 2011 | 07:08 PM
1bad04's Avatar
1bad04
Originally Posted by Dieselpop
Dieselpop What is the white plastic piece at the top of the cover?
Old May 1, 2011 | 07:23 PM
npccpartsman
IIRC that's where the air bleed is but not sure about the white plastic piece. I would not leave the fuel line attached to install the spring though.
Old May 1, 2011 | 07:39 PM
rdunagan's Avatar
rdunagan
glowshift has everything you need. the adaptor and the gauge. takes 30 mins max to install
