timing spout?
Old Dec 18, 2002 | 12:30 PM
scott bittner's Avatar
scott bittner
Post timing spout?
Due to a cracked head, I am installing a set of GT-40 turbo swirl aluminum heads and a set of flowtech shortys on my 94 f-150 this weekend, my question in where is the timing spout on the 94 302?
my truck is missing some of the stickers under the hood, and I am trying to avoid buying a book if possible.
Old Dec 18, 2002 | 12:56 PM
brown 4x4's Avatar
brown 4x4
timing spout?
The spout connector should be on the left fender near the firewall. It's right next to the EEC connector.
1995 F-150 Supercab XLT 155" 4x4 M5OD 302
1986 F-150 4x4 NP435 300
Old Dec 18, 2002 | 04:46 PM
Shadowjack's Avatar
Shadowjack
Post timing spout?
Piggybacking on this question, what does it look like? My '94 has a two-wire round connector with round male pins in it, is this it? The manual I have is a little vague about it.
Old Dec 18, 2002 | 06:36 PM
steve83's Avatar
steve83
timing spout?
[updated:LAST EDITED ON 18-Dec-02 AT 07:38 PM (EST)]If it has wires on each connector half, it should only have 1 terminal in each connector, but I think that style of SPOUT was only used in the mid-80s. The later style has both wires on one half of the connector and a small square shorting plug connecting the 2 terminals. It's pretty obvious because it's one of the few things you'll find with 2 PINK wires. It should be VERY close (like within a couple of inches) to the ignition module.
BTW SPOUT means "SPark OUT".
Old Dec 19, 2002 | 01:11 AM
charlez's Avatar
charlez
timing spout?
It should look similar to this....
http://members.tccoa.com/charlez/images/octaneplug.jpg
Old Dec 19, 2002 | 09:26 AM
scott bittner
timing spout?
Thanks everyone for their help, I'll log back in to you all know how the new power feels when I'm done, or sooner if I run into any snags along the way. Thanks again for the help. :-X12
Old Dec 19, 2002 | 03:40 PM
94van's Avatar
94van
timing spout?
Old Dec 19, 2002 | 04:52 PM
Shadowjack's Avatar
Shadowjack
timing spout?
Thanks--eventually found it buried in the wiring tape. Facing down and didn't look like it ever had been unplugged--in 178K miles!
