Sponsored by: Kumho
brake advice
Old Apr 28, 2011 | 06:37 PM
crushantz's Avatar
crushantz
brake advice
Recently replaced all four wheel cylinders on my 68 f250. I've thoroughly bled the system and there are no apparent leaks anywhere. However i dont get any response when breaking until the last fifth of the pedal movement. I dont see any leaks on the master cylinder but cant think of any other reason why the pedal response is so poor. Any sugestions?
Old Apr 28, 2011 | 07:14 PM
stuart1's Avatar
stuart1
Are the brakes adjusted properly?
There is an adjuster behind the M/C than can be turned out to apply it quicker.
Old Apr 29, 2011 | 10:17 AM
mark a.'s Avatar
mark a.
Maby the safety valve in the prop block tripped when you started bleeding ?
