Sponsored by: Real Truck
Tools Explained
Old Apr 28, 2011 | 09:45 AM
GUNNERDOG's Avatar
GUNNERDOG
Tools Explained
Someone sent this to me, i thought i would pass it along for a laugh.
Feel free to add your own...
Tools Explained
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, '$*!#'
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes , trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-BITCH TOOL: (A personal favorite!) Any handy tool that you grab and throw across the garage while yelling 'SON-OF-A-BITCH' at the top of your lungs. It is also, most often, the next tool that you will need.
Hope you found this informative.
Old Apr 28, 2011 | 10:31 AM
bunklash's Avatar
bunklash
Hilarious! Thanks for sharing this.
Old Apr 28, 2011 | 11:34 AM
Eatonpcat's Avatar
Eatonpcat
That's great!!!
Old Apr 28, 2011 | 01:06 PM
Monster-4's Avatar
Monster-4
Good one! I got plenty of the tool that is listed last. It reminds me of a few weeks ago when my little brother got new tires put on his car. They found a bad (and I do mean bad) front wheel bearing. He come over about 9pm and had to hit the road by 5am the next day to be somewhere. Anyway by about 11pm I was buttoning everything back up and couldn't get one of the brake caliper bolts to start. I lost it and kicked the tray that had the tools and parts I was using in it. Well after calming down enough to go and pick everything back up the only thing I couldn't find was the socket I needed for the brake caliper bolt. Spent 10 minutes looking for it.
Old Apr 28, 2011 | 01:08 PM
drey04's Avatar
drey04
too funny!
Old Apr 28, 2011 | 02:38 PM
fz1dave's Avatar
fz1dave
Super Duty
The sad thing is it's all true.
Old Apr 28, 2011 | 03:24 PM
maverick22's Avatar
maverick22
Hilarious! Only one I would add would be:
Arc Welder: Handy tool used to stick welding rods to project and for enlarging holes/gaps you were trying to close.
Old Apr 28, 2011 | 03:34 PM
barthel's Avatar
barthel
Originally Posted by GUNNERDOG
SON-OF-BITCH TOOL: Any handy tool that you grab and throw across the garage while yelling 'SON-OF-A-BITCH' at the top of your lungs. It is also, most often, the next tool that you will need.
VERY well acquainted with this tool, as well as the "DAMMIT" tool!
Old Apr 28, 2011 | 03:59 PM
sammy77's Avatar
sammy77
Damn thats funny!!!!!
Old Apr 28, 2011 | 04:45 PM
clem1226's Avatar
clem1226
Pressurized brake bleeder A device used to remove paint from the driver side fender of most domestic vehicles as well as provide a protective coating of brake fluid to the drivers side exhaust manifold/valve cover.
Old Apr 28, 2011 | 05:47 PM
I.B. Washincars's Avatar
I.B. Washincars
I've discovered that a pick and awl set is very handy for obtaining blood samples from fingertips
