i local guy on craiglist has a 77ish tailgate for cheap will this fit my 68 ?
i am going to look at today at 4pm .
i took measurements off my bed to be safe but hopefully some one knows for sure .
thanks in advance
mike
1973/79 F100/350 Styleside tailgate will fit 1967/72's, but the hinges are different as is the style, so it won't match the body lines.
C7TZ-9940700-A = 1967/72 F100/350 Styleside Tailgate-has a raised ovate scallop line that surrounds the FORD letters.
9/1966: Ford replaced the tailgate used on 1964/66 F100/250 2WD Stylesides and 1966 F100 4WD Stylesides (C4TZ-9940700-A) with the C7TZ tailgate.
All the mounting parts are the same. This tailgate (which is hard to find) has larger FORD block letters, does not have the raised ovate scallop line surrounding them.
Originally Posted by crazed87bronco
I'm pretty sure all 1961/79 tailgates are interchangeable.
Ach du lieber!No tailgate from a 1961/63 anything will fit-totally different beds! No 1961/63 Uni tailgate will fit.
And: 1961/65 F100/250 4WD's, 1963 F100/250 non Uni 2WD's, 1966 F250 4WD's and 1961/66 F350's used the 1957/60 Styleside bed. Called the "wrong bed" by enthusiasts of 1961/66's
No "wrong bed" Styleside tailgate will fit anything else.
THANKS
i took measurements off my beds body lines from point to point , they didn't match what he had so i passed on it . it also had 6 1/2" holes drilled in it for some kind of a tie downs.
Reason: typo
