'72 F-100 mpg info and dash lens replacement.
I have a '72 F-100 with a 390 engine, it's got an automatic transmission (C6 maybe- I am not too familiar with it since I have not had it for very long or get a chance to work on it yet). I am getting about 6-7 mpg, not sure if this is normal or should I be getting more than that, and if there is something I should look into replacing. She is my weekend truck, so not looking to get the gas milage like those crazy prius or whatnot. Just trying not to waste too much $$$ on gas, especially with this price nowadays.
Also, Cannot get a very acturate reading on my odometer since the dash lens appears to have been scratched or fogged over. Tried to replace them, but seems like the screws are reversely screwed in (I think), not sure the right approach to that, hope someone maybe have done this before and can point me toward the right direction. Like I said, I am pretty new at this old truck thing, so please excuse me for using the wrong terms. Thanks in advance.
Well, all I was saying is that you might have something like 4.10's while gliderider is running a 3.55 or something numerically lower. That would explain why you are getting so much less mileage. If it is all original, you should be able to decipher your vin number and data plate. It will tell you the gear ratio. There might also be a tag on one of the bolts on the differential telling what ratio it is. Last resort if the other two don't pan out is to pull the differential cover and count teeth.
Bear in mind I have a 71 work truck and couldn't see the gauges thru the cloudy/scratched dash lens. I had a box from a toy boat with a large see thru plastic window in it. I cut that out of the side of the box and with my dash front on the bench I took out the old plastic and patterened the new piece using it and reinstalled and it looks like brand new. That was a couple years ago. You can't tell it from orig.
The only way to accurately gauge mpg is by filling the truck, noting the mileage on the odometer and then doing some subtraction and division next time you fill up: miles traveled divided by gallons pumped/purchased. Either your odometer is off or you have a sick 390. My 69 F250 with 360 and C6 and 4.11 rear end gets 10.5 to 12.5 mpg, mostly in-town driving. I would check timing, do all the tune up stuff, clean the carb and run some Sea Foam through a tank of gas...then try to gauge the mpg.
Somewhere many years ago in a car magazine I read about this trick. I never tried it, but it makes sense.
Block all the wheels and put the transmission in neutral. Jack up one rear wheel and spin it one full revolution. Count the revolutions of the driveshaft as you do this. If the driveshaft spins 8.2 times, you have a 4.10 (double the ratio due to the differential and one wheel turning). If it spins about 7.5 times you have a 3.73. If it spins 7 times, you have a 3.54.
This all assumes you don't have a limited slip/positrac. Like I said, I never tried it, but it beats pulling the third member and counting teeth.
