A/C problem
Old Apr 26, 2011 | 05:26 PM
KLWillis's Avatar
KLWillis
A/C problem
All right guys. I have a 98' F150 with a 5.4. When idling the A/C works fine. When I accelerate heat begins to come out of the vents. It does not put out cold air again until the motor is back to idle speed. When adjusting the temperature, I can hear the blend door motor turn but I don't hear the blend door shutting. Should I hear it shut or do I have a vaccum problem. I don't know where to begin if it is in the vaccum hoses. Any suggestions will be appreciated.
Sincerely,
Roasting in Tennessee
Old Apr 26, 2011 | 06:49 PM
HomerWinzlow's Avatar
HomerWinzlow
98 blend door actuator is electronic so vacuum wont affect it. You likely have a broken blend door and when you accellerate the door flops open letting in the heat. You will need to remove the instrument panel to remove the top of the plenum and replace the door assembly which comes with a new frame for about 60 bucks.
tgspencer
Aug 9, 2015 06:25 PM
tgspencer
Oct 25, 2004 12:19 AM
Yelrisheam
Sep 27, 2003 09:58 PM
TMCALLISTER
Modular V10 (6.8l)
Jul 23, 2003 03:13 PM
kinglg
Jun 14, 2003 01:17 PM
