I have a 1995 F-150 5.0. It has dual tanks and I am trying to figure out if it has 2 or 3 fuel pumps. I thought it only had 1 in each tank, but someone told me that it has a 3rd or primary pump.
Hey Guys, Thanks for the responses. I have a starting problem that I am trying to diagnose. It happens on both tanks though. So I guess its not a fuel pump.
Does it crank fine have spark and you hear the fuel pump kick in ??
Is it below freezing were you are ?? Check out this tsb.
Make: FORD TRUCK
Model: F150
Year: 1900
Service Bulletin Number: BC4651961001
Bulletin Sequence Number: 57
Summary Description:
VEHICLE MAY NOT START AFTER BEING PARKED IN BELOW FREEZING TEMPS.
MAY BE DUE TO MOISTURE FREEZING IN THE FUEL PUMP RELAY CONTAINED
WITHIN THE CCRM (CONSTANT CONTROL RELAY MODULE). *TT
