Hi everyone, I'm new to the forum. I just bought a 95 f150 5.0L 2wd. When it's cold, the idle is very high and it runs rough. After it warms, the idle tends to calm down and the engine runs even worse, especially at around 30-40mph, or in OD.
Continuous memory had codes 332 and 334. Both the egr and position sensor have been replaced. As well as the vacuum solenoid and ports into the intake have been cleaned.
When I changed the wires and plugs (swapped out bosch super pluses for motorcraft copper) I noticed that 3 of them were fouled and 1 was oil fouled.
When the truck is allowed to excessively idle, a bluish white oily smelling cloud starts to seep out of the air pump check valve area of the engine bay, and out of the tailpipe in large amount.
Sorry I wrote so much, I just wanted to be as detailed as I can. Anyone run into something like this before? Thanks.
Noticed that no one got back to you on this post, so I'll pitch in a coupe of ideas.
More than likley, valve guide seals are worn, and that's your bluish smoke from tailpipe. That could also explain the oil fouled plug. This would be a good time for a compresion test. that will give you definate #'s for all cylinders and general overall health. Your looking at maybe $100 for head work and maybe around $200-$300 completely for new everything from head's and up. (New gaskets, etc) It's not bad, if the motor is in good shape.
Get a compression check and let us know. The tool is available perhaps for rent, if not spend $40 and it's yours for life.
Sorry for the lack of updates, I've been kinda busy with work and whatnot. Turns out cyl #3 is only puttin out about 30lbs of compression. I'm thinkin it's the valve seats. Good call on the comp check
I just wanted to say welcome to FTE.
Too much detail is never a problem here. Usually with newer members it's a lack of detail. Basically, the more information you can provide us with, the better we can help you.
