I HAVE A PUSH BUTTON IGNITION THAT WAS PUT IN A FEW YEARS BACK. EVERY NOW AND THEN THE STARTER SOUNDS LIKE IT IS STUCK OR SOMETHING. IF I PRESS THE BUTTON FAST MULTIPLE TIME IT EVENTUALLY STARTS BUT SOMETIMES IT TAKES A REALLY LONG TIME. PLEASE HELP WHAT DO YOU THINK IT CAN BE????? THANK YOU IN ADVANCE FOR YOUR HELP
Hey guys thank for responding its a 2001 Navigator and it is stuck and wont engage. If i press the button really quick it finally engages and starts but. what use to be every other week is now every other day.
That sounds like it may be a poor connection in the circut. I suggest that you inspect and clean every wire connection from the battery to the starter switch/button and then to the starter and don't overlook the ground wires. Look at the woven wire strap between the solenoid on the starter to the starter main body. I found a broken one on my Expedition that had starting problems when I bought it.
