1986 Having fuel issues...
Old May 12, 2011 | 11:04 AM
  #31
BPofMD's Avatar
BPofMD
Veteran: Navy
Charlie sends his best....and wondering if anyone has any more info on this? Has anyone thought about bad/dirty injectors?
Old May 21, 2011 | 07:59 PM
  #32
dustybumpers's Avatar
dustybumpers
~~~~~~Update~~~~~~~~
The 89 truck is repaired. winds up being the mechanical fuel transfer switch. that's the big can in the frame with all the lines hooked to it.
Old Jul 31, 2011 | 08:56 PM
  #33
heebegb's Avatar
heebegb
I have the same truck with the same problem. I replaced both fuel pumps, filters, pressure regulator, map sensor, TPS, oxygen sensor. Nothing fixed the problem. I finally decided I would study the chiltons manual, just replacing parts without knowing can get expensive real quick. The problem finally turned out to be the dual function reservoir. There is any easy test described in the manual, to see if thats the problem. Mine failed the test. Runs great now. I took the valve apart after I ordered the new one, and sure enough some of the o rings in the valve had come apart.
RFontenot
General Diesel Discussion
Jun 17, 2016 11:28 AM
RFontenot
6.7L Power Stroke Diesel
26
May 23, 2016 07:23 AM
misscali91
38
Mar 1, 2016 04:44 AM
tmancha
Sep 23, 2015 11:00 AM
acroberts08
44
Aug 26, 2015 12:33 AM
