Sponsored by: Real Truck
Cruise Control
Old Apr 24, 2011 | 11:49 PM
GeneLaw1's Avatar
GeneLaw1
Cruise Control
Hey guys,
06 F250 Powerstroke here, and I took it on its first roadtrip about 4 hours away to Charlotte, NC. Either way, it did well, I was proud of it!
There was a slight problem I noticed. When I was riding up, I had my cruise control set, and all of a sudden the truck jerked...the guages (mainly speedometer) moved in the opposite direction and then back to where they were. Then the "ABS" light illuminated. When I turned the truck off and back on the light went off. It did the EXACT same thing on the way back...
Anyone else ever experience anything like this??
Old Apr 25, 2011 | 03:51 AM
p-nut's Avatar
p-nut
There is a recall for the cruise control, you may want to check it out.
Old Apr 25, 2011 | 06:41 AM
projectSHO89's Avatar
projectSHO89
Nope, not on a 2006....
Old Apr 25, 2011 | 08:09 AM
jh818's Avatar
jh818
Maybe your VSS gone bad? It's the sensor on top of your rear diffdrential.
Old Apr 25, 2011 | 06:17 PM
projectSHO89
The totality of the described symptoms suggests a momentary interruption of power to the PCM/cluster.
I'd suggest starting by checking and cleaning the battery terminals and checking the condition of the cables. Beyond that, check the PCM Power Relay and check the fuse boxes for corrosion or loose connections.
Old Apr 26, 2011 | 07:16 AM
GeneLaw1's Avatar
GeneLaw1
Ok, thanks man, I will check those out!
greatmej
Jun 11, 2008 12:27 PM
greatmej
Jun 11, 2008 12:23 PM
PROSTOCK
Modular V10 (6.8l)
45
Apr 26, 2007 11:25 PM
Charlotte
1983 - 2012 Ranger & B-Series
Jan 26, 2004 09:07 PM
