engine trouble
Old Apr 24, 2011 | 11:08 PM
Mishka0204's Avatar
Mishka0204
engine trouble
So I live in Pennsylvania and we recently had a really bad storm. My car was stuck on a flooded road for a bit and I cannot get it started. It's a 96 explorer 4.0 and I did my best to dry all fuses and connections, smack the starter, which does hammer but engine won't turn over. I'd like to be optimistic and not think the engines ruined, but anyway all help would be greatly appreciated.
Old Apr 25, 2011 | 06:45 AM
shorod's Avatar
shorod
You might try removing all spark plugs an crank the engine over a few times to see if there's water in them. Was the flood water up to or over the exhaust tail pipe? You might have filled the exhaust with water. A quick test for this could be to remove the Sensor 1 oxygen sensors then see if the engine will start (with the spark plugs installed again).
-Rod
Old Apr 25, 2011 | 03:39 PM
Mishka0204's Avatar
Mishka0204
Yea it was over my exhaust a bit, the intake had water in it when i removed it, I changed the oil with no luck afterwards but I'm going to try the plugs and o2 sensor now
Old Apr 25, 2011 | 06:22 PM
senix's Avatar
senix
plugs, intake. Crank while the plugs are out. Hopefully even though it was hydrolocked there is no damage.
If it runs don't shut it off for a couple of hours. You want it to get good and hot, get all the condensation out of it.
Old Apr 25, 2011 | 08:20 PM
Mishka0204's Avatar
Mishka0204
I couldn't get the plugs out in my current situation, its getting towed to my house now then troubleshooting in the morning, I'm Gonna douche plug test tomorrow nd ill come back with feedback.
Old Apr 25, 2011 | 10:21 PM
aquanaut20's Avatar
aquanaut20
Water in the intake!.........
Do not even attempt to start until you pull all sparks and remove the water from cylinders (hydro locked).......
  • Sparks out..
  • fuel pump relay out...
  • crank till no spray from cylinders,
  • teaspoon of oil in each cylinder crank again...
  • install new plugs, FP relay and
  • start......
Philip
Old Apr 26, 2011 | 12:50 PM
Mishka0204's Avatar
Mishka0204
Very nice thank you very much will try ASAP
Old Apr 26, 2011 | 08:42 PM
Mishka0204's Avatar
Mishka0204
I got the new plugs today but didn't get around to trying that yet. Feedback tomorrow, thanks a lot guys!
Old Apr 27, 2011 | 02:25 PM
Mishka0204's Avatar
Mishka0204
Took the plugs out and still no motor turn. Any suggestions from here while the plugs are out
Old Apr 27, 2011 | 02:29 PM
senix's Avatar
senix
If you have the tools, then put a big socket and breaker bar on the vibration dampner and see if you can hand crank the motor over.
Vibration dampner is upfront, big pulley on the crankshaft.
You have good battery?
Old Apr 27, 2011 | 02:38 PM
aquanaut20's Avatar
aquanaut20
How long did this engine sit with water in it...? Ring might be stuck to cylinder walls.. Johnson bar on main crank and wiggle back and forth till free... Check for seized starter motor.... might ease load if you remove all accessory belts....
Old Apr 27, 2011 | 02:57 PM
Mishka0204's Avatar
Mishka0204
I tried to remove all water asap maybe 2 days on water I didn't find. I'm Gonna try the crank, I can't get a hatchet on the bolt tho would it work with just a wreck bar?
Old Apr 27, 2011 | 03:03 PM
senix's Avatar
senix
yes as long as you can get a socket on their and turn it over. All you want to do is break it loose. and then try the starter.
Plugs still out and a squirt of oil in each cylinder.
Old Apr 28, 2011 | 12:24 AM
Mishka0204's Avatar
Mishka0204
I'm Gonna have to pull my rad out to get the fan shroud off to a bolt on there. Feedback will be later tomorrow any thing.else you guys think of is love any suggestions. So if I crank the shaft and get it loose it should go afterwards? Thanks guys
Old Apr 28, 2011 | 05:00 AM
senix's Avatar
senix
possibly, unless the starter is also frozen. So you may end taking that off also.
