So I live in Pennsylvania and we recently had a really bad storm. My car was stuck on a flooded road for a bit and I cannot get it started. It's a 96 explorer 4.0 and I did my best to dry all fuses and connections, smack the starter, which does hammer but engine won't turn over. I'd like to be optimistic and not think the engines ruined, but anyway all help would be greatly appreciated.
You might try removing all spark plugs an crank the engine over a few times to see if there's water in them. Was the flood water up to or over the exhaust tail pipe? You might have filled the exhaust with water. A quick test for this could be to remove the Sensor 1 oxygen sensors then see if the engine will start (with the spark plugs installed again).
Yea it was over my exhaust a bit, the intake had water in it when i removed it, I changed the oil with no luck afterwards but I'm going to try the plugs and o2 sensor now
I couldn't get the plugs out in my current situation, its getting towed to my house now then troubleshooting in the morning, I'm Gonna douche plug test tomorrow nd ill come back with feedback.
How long did this engine sit with water in it...? Ring might be stuck to cylinder walls.. Johnson bar on main crank and wiggle back and forth till free... Check for seized starter motor.... might ease load if you remove all accessory belts....
I tried to remove all water asap maybe 2 days on water I didn't find. I'm Gonna try the crank, I can't get a hatchet on the bolt tho would it work with just a wreck bar?
I'm Gonna have to pull my rad out to get the fan shroud off to a bolt on there. Feedback will be later tomorrow any thing.else you guys think of is love any suggestions. So if I crank the shaft and get it loose it should go afterwards? Thanks guys
