Strange start up
Old Apr 24, 2011 | 09:07 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Strange start up
Hey all Happy Easter first off. Well i have noticed a differance in sound when starting my truck. Im curious as to if it could be the fuel pump starting to fail maby idk.
So I parked the truck fri after noon and all was well. Went out today "sunday" bout 12pm bout 85 to 90 degrees out. Cycled ignition on wait to start light went off and fired it up. Instead of going rurrr rurrrr rurrrrr rurrrrr rurrrrrrooommmm...... it sounded like a bad lope or a bogg. Kinda like Chugga Chugga sound. I know my sound effects dont help too much hahaha. So i drove 30 mi all was good. I shut the truck down and fired it back up after 5hrs it was still warm and it did the same thing.
On the way home it could have been my mind playing tricks on me but it dident seem too smooth douring acceleration or shifting into O/D. At one point going up a hill it shifted into O/D and it seemed to bogg out after the shift a bit. Like i said could just be my mind playing tricks on me.
I dont have a fuel pressure gauge, Engine oil should be good changed 2k mi ago and have no leaks anywhere. CCV is venting well, My Edge Evoiution has a built in code reader and i have no codes. I will try and record it in the morning if it dose it and post it.
I guess im just curious if anyone has encounterd this or has any suggestions on what would cause it to do this......
Thanks FTE
Old Apr 24, 2011 | 09:54 PM
bakerbuilttracks
bump ........
Old Apr 24, 2011 | 10:11 PM
snakedoc's Avatar
snakedoc
i would check the bat volts and connections maybe low volts to the starter.
Old Apr 24, 2011 | 10:15 PM
bakerbuilttracks
It looked to be in the norm... I always look at all the gauges prior to starting. Batt voltage looked to be in the correct spot between 12 and 14
Old Apr 24, 2011 | 10:34 PM
snakedoc's Avatar
snakedoc
just to be safe i would check them on the bat with a good meter. how much fuel is in the tank if it less than 1/4 there could be air in the fuel and that will make it run different.
Old Apr 25, 2011 | 06:15 AM
bakerbuilttracks
Full tank and I will get the meter out and check later. I just am bout to head to work just went out and started truck an it fired off great
Old Apr 25, 2011 | 06:42 AM
bakerbuilttracks
okay so I started the truck this morning and drove out the driveway real slow about 20 miles per hour and a truck was pulseating real bad. Bout half throttle it kept sounding like it would bogg out. I would accell harder and it would smooth out. still no codes
Old Apr 25, 2011 | 09:54 AM
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
When was the oil changed last? Time to buzz test your injectors.
Old Apr 25, 2011 | 08:32 PM
onesick02F350's Avatar
onesick02F350
I had the same problem in my 2002 7.3... turned out to be the IPR.
It didn't throw any codes either, I swapped in a friends IPR and it ran smooth again.
snakedoc's Avatar
snakedoc
might be IPR going or oil pump.
Old Apr 25, 2011 | 08:46 PM
bakerbuilttracks
Oil change 1k ago along with fuel filter
Old Apr 25, 2011 | 08:49 PM
bakerbuilttracks
Really ummmm well i got no codes showing up maby that could be it. I wish i could figure out a way to test it with our buying a new one. They are fairly expensive.
bakerbuilttracks
New hpop bout 2.5 or 3 years ago.
Old Apr 25, 2011 | 08:52 PM
bakerbuilttracks
OH checked fuel pressure today and it was all up to par. only other thing is the screens in the tank could be stopped up.
Old Apr 25, 2011 | 08:54 PM
snakedoc's Avatar
snakedoc
you might try and clean the ipr
New Page 0
