Hiss during boost leak test
Old Apr 24, 2011 | 08:19 PM
tonyndawn's Avatar
tonyndawn
I built the simple boost leak tester with the PVC cap and quick air disconnect. I found a couple of minor leaks on my boots, but there is a major hiss under and behind the turbo. I suspect it is the ebpv, but does it make sense that intake air could escape there? It is of course very hard to see, but I feel a definite stream coming from around a shaft of some sort, bottom passenger side if that helps.
First question, is this normal?
If not, is it the ebpv or something else?
Thanks,
Tony
Old Apr 24, 2011 | 09:31 PM
danskool's Avatar
danskool
Go Bills !
Air hissing is normal. Hisses so bad you just shut off your ears and just look for soap bubbles..
Old Apr 24, 2011 | 11:37 PM
tonyndawn's Avatar
tonyndawn
I hear ya on the soap bubbles, that's the only way I found the minor leaks at a few boots. But the hiss under the turbo is a solid stream, can definitely feel it with your fingers under there... Doesn't seem that air should be allowed out of the system there, even if it's bleeding past a valve and going through the exhaust.
Old Apr 25, 2011 | 05:02 AM
danskool's Avatar
danskool
Go Bills !
You can feel air with your fingers? I never felt around there, I just checked my boots. Curious.
rbmcveigh
Feb 17, 2015 09:04 AM
evan sussman
Oct 21, 2013 08:51 PM
BENG0924
22
Oct 10, 2008 07:10 AM
aklim
Apr 16, 2007 07:28 PM
alanc77
15
Feb 7, 2007 09:49 PM
