10 DTC's; what do the codes mean?
Old Apr 25, 2011 | 10:14 PM
m-chan68's Avatar
m-chan68
Originally Posted by bismic
Did you locate the TPS D,E,F sensors? If so, did you inspect the connector and wires?
Those three sensors are incorporated into the accelerator pedal itself.
Old Apr 25, 2011 | 10:27 PM
wildbonz's Avatar
wildbonz
Old Apr 25, 2011 | 10:36 PM
bismic's Avatar
bismic
Thanks Mike.
OP - From the 6.0L bible, here is a simplified diagram:
http://dan.prxy.org/Truck/6L_bible_h.../Page_049.html
Old Apr 25, 2011 | 10:41 PM
wildbonz's Avatar
wildbonz
Sorry, double posted the last one after I edited it a bit at the bottom.
I added; I know the battery voltage is a bit low now from repeated starts, key on-key off, and not being able to run, etc. It was fine when it happened. I have unhooked the batteries tonight and have the batteries charging. They were down to about 40%.
I unhooked the wiring to the pedal and it all looked good. I followed the wires up as far as I could and they looked fine.
Is it a bad pedal assembly? Or is a short causing all this? If so, how can I find it? What's my next step?
Old Apr 25, 2011 | 11:02 PM
m-chan68's Avatar
m-chan68
Based on the the three readings of the APP highlighted in BOLD RED in my previous post, I doubt that there is anything wrong with the pedal itself (but I could be wrong), but rather something else that is causing the decreased V-Ref voltage reading that's causing your issue. I would start by uplugging three wire sensors until accelerator pedal control of engine speed is restored as a start, beginning with your EBP sensor first, to be followed by the ICP sensor and then the fan clutch connector and so on.
Old Apr 25, 2011 | 11:13 PM
3000 FPS's Avatar
3000 FPS
I have a neighbor who had a similiar problem after washing the engine compart down with a hose. It did not show up until a day later. It turned out to be a connector under the hood that had water in it. He thought it was his accelerator pedal so I let him take the one out of my truck and try it on his and found out that was not the problem. That is when he started checking under the hood.
Old Apr 26, 2011 | 01:33 AM
wildbonz's Avatar
wildbonz
So should I unplug one at a time, then try to start it?
Do I reconnect each one if it doesn't change anything and go on to the next one?
Thanks
Old Apr 26, 2011 | 09:58 AM
brickie's Avatar
brickie
DTS Common 6.0L Wiring Problems here are some common spots that the harness chafes.Yes you need to disconnect the sensors one at a time.
Old Apr 26, 2011 | 01:14 PM
wildbonz's Avatar
wildbonz
Couldn't find anything.
I unplugged all the sensors I could find one at a time. No change.
The only thing different was that when I redonnected the batteries this morning after charging them, only the wrench light was on. No check engine light.
That's the same as when it first happened. Then the check engine light came on after I started unhooking everything.
Old Aug 31, 2011 | 04:40 PM
John Irwin's Avatar
John Irwin
Any update on this? Having the same problem.
Old Sep 4, 2011 | 09:45 PM
wildbonz's Avatar
wildbonz
The dealership took it in and had it there for 5 days. They replaced the throttle pedal assembly. It cost around $700. It worked fine for a couple months, then it started doing it again.
It would randomly go into idle and nothing else. I could drive it at 3 mph and if I shut it off and started it it would often go back to normal.
Then one day it left me stranded out of town with the same problem.
My dealership wouldn't cover it even though it was the exact same problem they "fixed". Said I would have to tow it back and start a new bill.
That was until I contacted Ford customer care. The dealership suddenly took it in right away instead of the 2 week wait they said it would be. Had it back the next day. No charge. Said bring it back if anything goes wrong.
Ends up it was a corroded connector somewhere.
Old Sep 4, 2011 | 09:48 PM
wildbonz's Avatar
wildbonz
Has been running great since. Also have the peace of mind that the head gaskets and injectors are good. They checked all that.
I'll try and find out which connector if you want.
Old Sep 5, 2011 | 11:05 AM
  #28
John Irwin's Avatar
John Irwin
That's ok, I'll chase it down. Thanks.
Old Aug 14, 2024 | 10:48 PM
  #29
adamlerma's Avatar
adamlerma
2nd Gear
having the same problem! What connector was it?
Old Aug 14, 2024 | 11:29 PM
  #30
bismic's Avatar
bismic
What year engine do you have? It could be one of the mid harness connectors (12 way connector mentioned in post #11).
Sometimes there is a correlation between these codes and the EBP sensor. That can be tested by disconnecting the EBP sensor.
Best to provide codes and readings like the OP did - if you really want to solve the issue. It is a good chance your issue isn't EXACTLY like the OPs.
Verbalizing (in writing) your exact symptoms might help also.
