Computer Chips & Tuners
which tuner or chip do i need
Old Apr 24, 2011 | 10:54 AM
gjnicholas's Avatar
gjnicholas
I have a 95 bronco with 5.8 and was wondering if there is a chip or tuner that would give me a little more hp and torque.
thanks in advance
Old Apr 24, 2011 | 11:55 AM
Conanski's Avatar
Conanski
Short answer is... yes.. but you can get the same gains for free by simply advancing the base timing.
The EFI system in that vintage truck is very basic which is both a blessing and a curse, there aren't many plug-in tuning devices available and there isn't much for those devices to adjust, but since the motor still has a distributor changing the overall timing advance is easily accomplished with a timing light and a wrench. And because the EFI system is so simple it won't counteract thing you do to increase airflow through the motor, so installing a free flowing exhaust or 1.7 roller rockers will produce power gains.
Old Apr 24, 2011 | 12:29 PM
gjnicholas's Avatar
gjnicholas
I already have timing advanced all i can without the valve clattering.
so i can change just the rockers and pick up some ponies or did i miss read your post
Old Apr 24, 2011 | 06:58 PM
Conanski's Avatar
Conanski
Yeah that's right, 1.7 rockers will poke the valves open a little more(stock ratio is 1.6) which will increase airflow through the motor and make more power.
Old May 11, 2011 | 02:45 PM
Green Griffin 420's Avatar
Green Griffin 420
Which style rocker will be needed, Pedestal mount or stud mount? I'm planning on doing the same thing to my 94.
wnterlog
Modular V8 (4.6L, 5.4L)
May 24, 2014 09:49 PM
Dieselpower22
13
May 30, 2013 01:07 PM
mcallister
May 4, 2008 11:26 AM
blhfla
15
Dec 16, 2005 05:13 PM
