Well picked up 8 used injectors with less then 81k on them for 400 this week. Got them the other day they look in good shape .Next ordering the injector o-rings for them . When im at it I have a IHOP line that been leaking . looks like the o-ring is shot so that will be fixed . and when I got every thing else apart im going to swap out my pedestal with one I have done the ebpv delete to. its been leaking . So got a full day of work in the next week. Think when I get the chance and money going to send out my old injectors and get them rebuilt .. after all the work hopefully i get all the oil leaks ..Just wish the price on fuel would drop its getting crazy . But will see if the injectors fix my cold start problem . which Ive diag down do injectors not operating correctly when oil is cold.... wish me luck ....
Wish you luck. I would toss in 8 new glow plugs also. 50 cent mod, intank mods. HPX. Stancor relay. Pop in a new fuel filter and change to synthetic oil. After that plus fix the oil leaks and run a compression test. That baby should start at 32 degrees after 15 seconds on key on. Mize well spend the whole weekend. Fuel prices are making us park our trucks, So good time to get stuff done.
IPOP is actually not leaking one of the lines is bad o-ring. the glow plugs are actually less then a year old , but when im in there im going to check them out have to pull them any ways .GRRR dam fuel prices are crazy its $4.39 a gal last time I checked here which is beyond crazy since its gone up over a $ 1 sine Jan 1st 2011...
Charging zx1100 Ninja battery now and wish it would stop raining. Looking for a cheap eco car again so i can put the truck to sleep in the garage. They making it harder and harder to retire early. Save your pennies were you can. Going to need it.
