Is that another one of those "how far west is actually east" type questions? :flipoff:
bwahahahahaha!!!!!!
i'm just glad i didn't have to ask this newb question. my hubs are effed up, one is stuck and neither of the caps are in the right position so the dial points at nothing.
lol this question could have been avoided competely just turn em both one direction put it in gravel or wet grass and mash it see if the front catches traction. if nothing happens turn em the other way.
Dan, get you an allen wrench (5/32" sounds right) and pull the cover off. You should be able to fiddle with the dial and internals to make it work/point correctly. If not let me know and I might be able to send you a set of 44 hubs.
kris after posting that i remembered i got the one hub to turn the other day with a pair of pliers and now i can turn it by hand. the truck sat for the last few years so they might just need to be tore down and cleaned/greased up. hubs aren't near the top of the to do list right now, but thanks, i'll hit you up if there's an issue.
