Sponsored by: Auxito
Spare Tire
Old Apr 23, 2011 | 08:46 AM
bfaulkner's Avatar
bfaulkner
Spare Tire
Hey Y'all!
Gotta 99 F-150. It has been awhile since I tried lowering the spare tire down from under my truck. (I know I should use it on a regular basis to keep this from happening) Well I tried last night and the rod won't even lock in to crank it down. Its probably full of rust from not using it. shot a bunch of WD-40 up in there and let it sit. If I can't still get the rod in there how would I go about and get the spare down? Any suggestions?
Old Apr 23, 2011 | 09:09 AM
shorebird's Avatar
shorebird
Have you lowered it before?
Do you have the security key for the spare?
Old Apr 23, 2011 | 11:05 AM
bfaulkner's Avatar
bfaulkner
I have lowered it before but it has been quite awhile and there was never a security key for my truck at least.
Old Apr 23, 2011 | 01:46 PM
Ultramagdan's Avatar
Ultramagdan
If the rod won't lock in it might have a bunch of dust sucked up in there that is preventing the rod from engaging. Take to a car wash and stick the wand up there as far as you can and see if that will clean it out enough.
Old Apr 24, 2011 | 06:32 PM
Spotty's Avatar
Spotty
Mine broke about 6 months ago. Wound up taking my angle grinder and cutting the piece off the end of the cable so the tire would come off. That whole assembly unbolts from the frame with I think 2 bolts. I took mine off, tried to fix, but no good. I'm sure you can buy a new assembly, but being the cheapo I am, I took a piece of steel and welded a 1/2" bolt on it and mounted that back up where the assembly use to be. I took another small piece of steel, drilled a hole in it. Then I lfted the tire up with the hub thru the bolt, then the piece of steel, then double nutted it. To be honest it is a real PITA to take the tire on and off that bolt....but it works and money is tight these days being in construction and all. Good luck with all...
Old Apr 24, 2011 | 07:01 PM
rsylvstr's Avatar
rsylvstr
I'm on my third assembly...a little PM would probably cost less!
Orezona
17
Jul 9, 2006 12:09 PM
B A dawg
Apr 2, 2005 05:41 PM
Marlo121
Feb 3, 2005 05:53 PM
echoy97
Escape & Escape Hybrid
Aug 19, 2004 05:34 PM
anthony605
Oct 30, 2003 12:37 PM
