5.0L distributor question
Old Apr 23, 2011 | 08:00 AM
dsc's Avatar
dsc
I replaced my 1989 F150 5.0L engine with a rebuilt F150 5.0L eng.
My 1989 eng had a roller cam which was stock and the replacement is a roller also.
My question is. Are the distributors the same, they look the same? I gave away the old 1993 distributor and don’t have it to compare length etc. I know the drive gear must be for a roller. I put the 1989 in the engine and works ok but as per a pervious post I am having oil pressure issues. Thanks Art
Old Apr 23, 2011 | 04:02 PM
xlt4wd90's Avatar
xlt4wd90
If both engines used roller cams, they should both have steel distributor gears. You can look for obvious problems, like metal filings from a ground up gear, or the hex hole at the base of the distributor shaft rounding out, or the oil pump drive shaft hex rounding out. But the problems should be obvious; as long as there is gear-to-gear drive, the distributor will turn, or the engine won't run. As long as the the distributor or drive shafts haven't been completely rounded off, the oil pump should be turning with the distributor.
I didn't follow your other thread, but low oil pressure on a newly rebuilt engine would point to the engine. Did it get a new oil pump with the rebuild?
Old Apr 23, 2011 | 05:04 PM
dsc's Avatar
dsc
Thanks for the response. I guess I was unclear. The original eng in the 1989 truck was a 1989 5.0; roller. I rebuilt a 1993 f150 5.0L roller. I used the distributor out of the 1989 to put in the 1993 because of the electrical connection to the eng harness. The eng would start and run fine with normal oil pressure at 2500 rpm's a drop to zero at idle. Also there is no oil pressure to the rockers. Thanks Art
Old Apr 23, 2011 | 05:15 PM
MisterCMK's Avatar
MisterCMK
What have you checked so far?
Old Apr 23, 2011 | 06:22 PM
dsc's Avatar
dsc
After Initial start up the dash gauge would read 3/4 scale oil pressure at 2500 rpm. Decrease to 1500 guage went to zero. I know dash guage is limited. I was concerned if oil was getting to valves. Opened the valve cover it was dry.
Checked the following:
Drained oil checked clearance of screen to bottom of pan
Installed real oil gage and turned distributor with an electric drill go got abut 10 psi; don’t know how much pressure would get with just a drill.
Looked down distributor hole and saw no oil flowing on dist gear.
Changed to a different oil filter and while it was off turn the oil pump again and lots of oil pumped out.
Old Apr 23, 2011 | 07:00 PM
MisterCMK's Avatar
MisterCMK
How did the pickup look when you put the pan on? Was the oil pump new?
Old Apr 23, 2011 | 09:21 PM
dsc's Avatar
dsc
Sorry I ment oil filter. ran drill and oil flowed like a river. Thanks Art
Old Apr 23, 2011 | 09:30 PM
MisterCMK's Avatar
MisterCMK
Have you run it with the mechanical gauge hooked up?
fordboy97
Oct 21, 2015 08:42 PM
cubinzkid
Sep 28, 2014 09:08 PM
dsc
17
Apr 20, 2011 06:54 AM
mvvette97
15
Feb 25, 2007 06:01 PM
300six1990
20
Feb 15, 2006 02:39 PM
