Bronco Graveyard Carpet
Old Apr 22, 2011 | 12:21 PM
devino246's Avatar
devino246
Question Bronco Graveyard Carpet
Has anyone ordered carpet from Bronco Graveyard? The carpet in my truck is crap and BG has the best price. I dont wanna shell out $125 and get a POS.
Old Apr 22, 2011 | 12:31 PM
bucks77ford's Avatar
bucks77ford
They get their carpet from ACC which supplies their carpet to many places. This is one of those "things" that gets brought up pretty frequently. Since they supply to many companies, chances are most places you order from will supply ACC carpet. It's going to be one of those things that is a hit or miss. I've heard/seen many who are very pleased and also heard/seen some that seemed to not fit properly. Mine doesn't fit properly up by the kickpanels. It seems like it was not wide enough, but fit well in the rest of the truck. I guess I wouldn't hesitate too much because the chances are you'll probably be happy with it, but just wanted to let you know that there are some that seemed to be off. I've heard some good things from SMS fabrics http://www.smsautofabrics.com/
Old Apr 22, 2011 | 01:29 PM
devino246's Avatar
devino246
Thanks, Ill do it when I get enough cash saved up.
Old Apr 22, 2011 | 05:52 PM
Blackfoot Big Block's Avatar
Blackfoot Big Block
I'm one of the folks who think ACC carpet is, to put it succinctly, "crap" (opinion based on personal experience).
Unfortunately, the last time I checked SMS Fabrics sells ACC carpet. I don't know of any vendor supplying a quality carpet for our dentsides.
Old Apr 22, 2011 | 06:16 PM
devino246's Avatar
devino246
Ill take what I can get, anything is better than the crap thats in there now.
Have any experience with the molded polyvinyl mats?
Old Apr 22, 2011 | 08:00 PM
bucks77ford
If you don't mind having a mat in your truck, I'd actually think about having the floor rhinolined to act as your mat and you would be able to wash the floor out.
Old Apr 22, 2011 | 08:58 PM
devino246's Avatar
devino246
Hmm, not a bad idea. Would Rust-Oleum truck bed lining be any good? And would that make it much louder than it is now?
Old Apr 22, 2011 | 09:20 PM
77_150_460's Avatar
77_150_460
I bit the bullet on the ACC carpet not long ago despite warnings on this forum and elsewhere. Since they claimed it is not cut until ordered - I added a request that the sides have an extra couple inches added. Whether they actually listened or if they have just changed their ways, I had an extra 2" on either side. No matter what - there is a need to specify tall hump or low hump transmission tunnels, if the place you are ordering from does not have that option, chances are they do not know enough to properly order the carpet for you.
I did drive the truck for a while with only rustoleum bed liner on the underside of the floors - it was much louder. More road and engine noise got through. Just depends on how picky you are with that. I now have bed liner under the floor on the outside, a super sticky sound mat covering the floor inside, and the factory style sound deadening material attached to my new carpet. No complaints.
Old Apr 22, 2011 | 09:34 PM
devino246's Avatar
devino246
I may go ahead and do the bed liner, and then get carpet later. Right now theres a $300 list of things I want to do. The truck will be my daily driver; using it for around town & to get to school, so I dont think road noise will be that much of a nuisance. How many quarts of bed liner did it take?
Old Apr 22, 2011 | 09:38 PM
77_150_460's Avatar
77_150_460
I used the amount recommended for a mini-truck bed, I do not recall how much that was, but I still had some left over.
Old Apr 22, 2011 | 09:48 PM
devino246's Avatar
devino246
Ok, thanks guys!
Old Apr 23, 2011 | 06:55 AM
Blown 331's Avatar
Blown 331
I installed the pre-molded, full cab vinyl mat from JBG in my 77, love it. It had to be trimmed to fit but the quality and molding was great. And its a full mat, not a half mat like factory.
Old Jun 4, 2011 | 08:14 PM
devino246's Avatar
devino246
Finally got around to ripping out the old carpet. There was some rust on the edges of both the DS and PS floorboards. The PS had rusted through and crudely relaired by one of the POs. I has some sheet laying around that I welded in until I can get some good metal to correctly repair it. One quart of liner was plenty for two coats.
Old Jun 4, 2011 | 09:20 PM
davethecow's Avatar
davethecow
I had the same problem Bucks had with the carpet being a bit short by the kick panels. But i installed kick panel speakers and those coverd the flaw.
White76
Mar 26, 2016 09:03 PM
85MOTORSPORTXLT
Dec 20, 2015 11:18 AM
MixWizard
Nov 27, 2015 06:06 PM
ojosdestranger
1978 - 1996 Big Bronco
Sep 15, 2004 09:05 AM
harleynascar
16
May 25, 2004 10:23 PM
