couple engine problems, possibly all related.
Old Apr 22, 2011 | 12:06 PM
paintslinga2010's Avatar
paintslinga2010
Truck is a 89 f250 351 zf tranny. We were having issues with the truck wanting to die when releasing the clutch so we took it and had a new slave cylinder and clutch kit installed. This helped the drive-ability some but its still not right. When letting out the clutch I have to be overly light with it and feather it or the truck wants to die. I also feel like the rpms have to be higher than usual to take off also. The other thing is at stoplight the truck rocks back and forth. It has a cam but I drove it for a year and it never rocked like this. So what do you guys think it is? IAC? Timing?
Thanks
Old Apr 23, 2011 | 06:17 PM
paintslinga2010
Anyone? I think this should be something simple I just don't know where to start.
Old May 27, 2011 | 06:10 PM
paintslinga2010
one more time...
Old Jun 1, 2011 | 08:24 PM
EPNCSU2006's Avatar
EPNCSU2006
Have you checked for codes in the computer? It might not tell you exactly what's wrong, but may give a general direction of where to start looking.
Old Jun 1, 2011 | 10:33 PM
1992ford302's Avatar
1992ford302
i had some what of the same problem with my automatic truck it was the timing just a good idea to check that, that can mess up your whole driveablity. Or check for leaks around the intake/vaccum area one open vaccum port can be alittle problem that can throw the whole motor off.
Old Jun 1, 2011 | 11:28 PM
andym's Avatar
andym
I would also start by checking for vacuum leaks. How much vacuum does it pull at idle?
Old Jun 1, 2011 | 11:38 PM
Encho's Avatar
Encho
The Southernmost Mod
I'm pretty sure it's a sensor, try the IAC or TPS, but before anything else, check for codes, that's usually the faster way to point at the cause.
quakerj
34
Jan 13, 2014 09:37 PM
strokin'_tatsch
Sep 23, 2013 11:59 PM
4inchlovin
Feb 24, 2012 05:06 PM
nikolass
13
Apr 23, 2009 09:03 PM
Oldchap
Aug 26, 2007 07:05 PM
