1978 - 1996 Big Bronco
Bronco body on f150 short box frame?
Old 11-08-2018, 09:51 AM
pat420swed's Avatar
pat420swed
pat420swed is offline
the frame under my bronco is pretty rotted. Has anyone on here done a frame swap with a short box f150? What kind of work is involved?
Old 11-14-2018, 03:18 AM
75BigBlock's Avatar
75BigBlock
75BigBlock is offline
I don't know what year Bronco and F150 you're considering, but my 77 F100 SWB and 78 Bronco have significantly different wheelbases. My Bronco has a wheelbase of 104" and my F100 has a wheelbase of 117". So... without relocating the rear axle, the rear body of the Bronco would basically sit on the rear wheels rather than the wheels going into the wheel well. If it was just a matter of moving the rear axle forward, you'd still have about a foot of frame sticking past the tailgate of the Bronco. This is just me visualizing things here, so other than that I have no idea what is or isn't possible. Yes, my F100 is 2wd, but for the sake of frame length comparison it's the same thing.
Here's a pic of my two rigs. It's kinda hard to see the length difference between the two until you look at the distance from right behind the cab to the front of the rear wheels on each one or visualize the top of the Bronco on the bed of the truck.
Old 11-14-2018, 06:53 PM
Bruners4's Avatar
Bruners4
Bruners4 is offline
I've been discussing putting a Bronco tub on a F250 4x4 of the same series. It would be a project of shorting the frame and putting on some new body mounts for the Bronco tub. That then would give me all of the F250 7.3L engine and drivetrain and the strength for the additional weight of the diesel engine. Then all of the dash and wiring would have to be switched and modified for the additional Bronco only options like the rear window. More project than I want to tackle.
Old 11-14-2018, 07:14 PM
metalsmith's Avatar
metalsmith
metalsmith is offline
I figure there is 25.4 inches of frame to cut out to make an 8 foot box / frame fit a bronco body. That is a lot of frame chopping....
Old 11-16-2018, 07:49 PM
75BigBlock's Avatar
75BigBlock
On the other hand, I have seen this swap done the other way with someone putting an F-series cab on a Bronco frame. It was a straight swap, but they ended up with this reeeeally short flatbed. Looked pretty comical.
mefast
10-27-2014 07:21 PM
cis2711
08-28-2011 09:13 PM
Black_Stallion
03-21-2010 02:14 PM
ranger_4x
07-12-2002 01:51 PM
Quick Reply: Bronco body on f150 short box frame?
