Every time I turn off my truck, I get this strange noise from under the hood. Sounds like pressure bleeding off through a diaphram of some sort. Takes about 10-15 seconds to complete.
Is this normal? Maybe my fuel pressure regulator going bad?
Ok, I found it. It's the EVR. It's really pretty loud, especially with the hood up.
When I turn off the truck and pull the vacuum line that goes to the EGR valve, the EVR quits making noise. If I put that line back on quickly, it starts making noise again...apparently until all the vacuum bleeds off.
Does that mean the EVR is going (or already is) bad?
