aod indicator keeps blinking on shifter????????
Old Dec 2, 2002 | 04:11 PM
talldog's Avatar
talldog
can anyone explain this
Old Dec 2, 2002 | 06:53 PM
edenroadmaster's Avatar
edenroadmaster
your trans is in "limp" mode. the computer is reading an error code in the trans. i sugest taking it to a dealer or to a shop with a diagnostic tool to see what needs fixed.
hope it helps
eden
Old Dec 2, 2002 | 08:57 PM
Mr Personality's Avatar
Mr Personality
I have the same problem. Is the light blinking in a random, and sporatic manner or is it on and off continuously. I posted a few weeks back about mine flashing intermittently (off sometimes for a while, and then flashing and quite intermittent) and received a reply that it was probably just a loose connection or bad bulb. It is probably a better question for the folks in the trani forum, but if anyone can clarify what type of flashing a trani sending codes will give on that little column shifter light, it may help.
Mine shift and drives fine both in OD and locked out, so I haven't done much about it except wonder ???
Doug
92 F250 SC 4X4 460auto
Old Dec 2, 2002 | 10:48 PM
steve83's Avatar
steve83
It's not an AOD - it's an E4OD (or possibly a 4R70W). If you pull the codes from the engine computer, they should tell you what's up with the transmission.
Old Dec 20, 2002 | 04:10 PM
jimbob93's Avatar
jimbob93
Post aod indicator keeps blinking on shifter????????
i had that problem around '94. Luckily it was still under warranty. The dealership just replaced the whole shifter stock. No problem since. God bless Henry Ford.
Old Dec 20, 2002 | 04:53 PM
jimbob93's Avatar
jimbob93
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
