79 f250
Old Apr 21, 2011 | 02:18 PM
natef250's Avatar
natef250
Question 79 f250
what would give more power to a 460 a carbuerator or fuel injection
Old Apr 22, 2011 | 12:19 AM
640 CI Aluminum FORD's Avatar
Depends on what the application is.
A Carbed 460 would probably be the best way to go if its going to be used mostly as a mudder/drag racer...etc...etc. Carbs are easier to work on, and can really push large amounts of fuel into the engine for more power and if you really want to go to the extream you can mount 2 or 3 4bbl carbs on your engine. But they generally have a few quirks and don't run as smoothly as a fuel injected engine.
A Fuel Injected 460 would be the way to go if you have mixed dutys planned for the vehicle. If you plan to use it as a daily driver and maybe just every now then take it out to play. Then a Fuel Injected system would probably work better. It'll be smoother, less prone to issues, and you'll get a little better fuel econmy out of it. With the right tuning a Fuel Injected 460 can make every bit the power a Carbed 460 can...And be more liveable on day to day basis as well...But it'll be more complex to work on, and shops will charge more to do tuning and extensive work on a Fuel Injected engine.
Old Apr 22, 2011 | 12:58 AM
LxMan1's Avatar
LxMan1
Moved to correct forum.
1972ford250
Apr 24, 2008 12:20 AM
f250kingranch
Ford vs The Competition
24
Jun 11, 2006 07:21 AM
powerstroker250
Jul 6, 2001 08:02 AM
powerstroker250
Jul 5, 2001 03:40 PM
jbhf250
Apr 1, 2000 08:25 PM
