Ford 460 flywheel
Old Apr 21, 2011 | 09:14 AM
401477534's Avatar
401477534
Ford 460 flywheel
I was wondering if a ford 351m/400 flywheel will fit a 429/460?(someone has a listing on craigslist for one and says it will) I am thinking of putting a manual in my truck, and need a flywheel...but I think the bolt pattern on the crank is different...If not that would be awesome if they interchange.
Thanks
Old Apr 21, 2011 | 11:46 AM
thechief66's Avatar
thechief66
The bolt pattern on the bellhousings are the same, but the flywheels are different.
Old Apr 21, 2011 | 05:04 PM
401477534's Avatar
401477534
Thats what I thought, When I saw that add I thought id ask to make sure if it would work. Thanks.
Old Apr 29, 2011 | 07:47 PM
Chiefrider007's Avatar
Chiefrider007
Also the bellhousings aren't the same thickness. A bellhousing off a 400 will bolt to a 460 but not without either using spacers or leaving the cluth/pressure plate out of it, to the best of my knowledge.
Old Apr 30, 2011 | 09:30 PM
401477534's Avatar
401477534
I found an 84 parts truck with a 460 and 4 speed, hopefully the bell will be there by the time i get to it.
Dodge-My-Cummins
Jan 19, 2015 07:53 AM
F350moneypit
Aug 23, 2009 06:29 PM
johncart
40
Sep 29, 2008 12:05 AM
ford_boy_1996
Nov 13, 2007 08:15 PM
