Transmission Wont Shift
Old Apr 21, 2011 | 08:27 AM
hortonp24's Avatar
hortonp24
Hey guys i have a 1977 Ford F-100 With a 302. I just had my transmission rebuilt and now it wont shift out of first. I have ran out of ideas. Any ideas on what could be the problem? I need to fix it so i can sell it and get a newer ford truck. Thanks
Old Apr 21, 2011 | 08:49 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Is it under any type of warranty from the shop? If so take it back. Did you test drive it when you picked it up, and it worked correctly right? Ck the fluid correctly?
Did the vacuum line come off from the intake manifold? Is the gear shift lever hooked up correctly? Or have you checked the linkage?
Old Apr 21, 2011 | 09:02 AM
hortonp24's Avatar
hortonp24
when i picked it up it ran fine shifted fine i test drove it and everything was fine then 3 or 4 days later the flywheel cracked and i had them replace it and ever since then it hasnt been shifting right everything is hooked up
Old Apr 21, 2011 | 09:47 AM
77&79F250's Avatar
77&79F250
Well since they replaced the fly wheel (over torque the hdwr)? It should still be covered by some kind of warranty 30 days or 1000 miles???? Unless they are a shady place????
If I took a vehicle to a place with a good xmsn for a repair to something other than that and then all of a sudden it is not working, they damn sure would be fixing it.
Especially since they just fixed the xmsn, its on them, sorry I have no other suggestions on what to ck.
But sounds like they screwed up again. Did you test drive it the second time you picked it up? And it was good? Did they test drive after they replaced the flywheel? You have to drop the xmsn to change the fly wheel so.......I would think they would test drive it.
This place sounds shadier than 2 miles up ol booger hollar creek at sun down.
Old Apr 21, 2011 | 10:20 AM
78 PEB's Avatar
78 PEB
I'd be on them like stink on sh** to make em fix it. I'm sure you paid good money to have it repaired and it should be right after they are done. If you are unsuccessful at getting them to do anything, Take the truck to a well seen parking lot on the busiest street in your town. Make up some signs that say "This truck had its transmission repaired by (whoever it was) And now it wont move!!!!" Hang them on both sides and let it sit there for a week or two.....................Then tell every one you know not to take anything to that place............You might not get your truck running, but you CAN get even.......... This kind of thing is why I started working on my own stuff when I was first starting to drive. I got tired of getting screwed by so called "professional" shops.
Old Apr 21, 2011 | 10:46 AM
77&79F250's Avatar
77&79F250
I would park it right in front of their shop or business (on a public road of course) if they will not make it right. Don't let them get away with it!
Most xmsn shops are crooked as a bag of snakes! Sorry if this offends someone that owns a xmsn business, but you know what I mean...
Old Apr 21, 2011 | 10:55 AM
hortonp24's Avatar
hortonp24
HAHAHAHA Yeah its sitting at the shop now! i twill shift into second manually but when i put it in drive it shifts down to first. im out of ideas. u think anybody on here would buy it and take the time to figure it out and get it running right?
Old Apr 21, 2011 | 11:01 AM
78 PEB's Avatar
78 PEB
So whats the deal??? Have you talked to them about making it right? Did they refuse to do anything about it? Or don't they know whats going on???
Old Apr 21, 2011 | 11:09 AM
hortonp24's Avatar
hortonp24
I talked to them and there response was well try to make things right and fix it!
Old Apr 21, 2011 | 11:13 AM
77&79F250's Avatar
77&79F250
Glad to hear they are willing to fix it. As far as selling it with a xmsn problem you will take a loss on the price.
Just get them to fix it, sounds like its their fault anyway. Oh forgot to mention, is the kick down lever installed correctly?
Old Apr 21, 2011 | 11:16 AM
78 PEB's Avatar
78 PEB
Glad to hear they are going to take care of it!!!!!!!!!!
Old Apr 21, 2011 | 11:33 AM
jim collins's Avatar
jim collins
If they said they would make it right,then they have allready admitted they are in the wrong. Make them fix it , install another trany, or give a full refund back and if they don't get at it right away ,then that's to their advantage because it makes it look like you really don't care. If they move it out of the shop,then do what was suggested with the signs on a public street. Keep us in the loop as to what happens, good luck. JIM
Old Apr 22, 2011 | 08:23 AM
hortonp24's Avatar
hortonp24
ill let u guys know what happens and i didnt check the kick down lever. i know this is off topic but how do u get ur cars picture beside ur names i just want to see what u guys think about pricing with the trans problem and after it gets fixed. if that makes any sense
Old Apr 22, 2011 | 08:29 AM
ford_pickup's Avatar
ford_pickup
hey if its any help, my truck did that exact same thing, I found that the vacuum modulator was not hooked up, drove perfect after that, and I mean it did the EXACT same thing
Old Apr 27, 2011 | 09:47 AM
hortonp24's Avatar
hortonp24
Thank Yyou guys for all ur help. They have been searching for the problems and im still waiting to hear from them. if i do get it fixed how much do u think i could sell it for? But if i dont get it fixed what would be a good price?
