Fueling tips
Old Apr 21, 2011 | 06:34 AM
cford716's Avatar
cford716
Fueling tips
I was sent this, don't know if it is factual or not. Seems to make sense. Take it or leave it. (Every drop counts now.)
I don't know what you guys are paying for gasoline.... but here in California we are paying up to $3.75 to $4.10 per gallon. My line of work is in petroleum for about 31 years now, so here are some tricks to get more of your money's worth for every gallon:
Here at the Kinder Morgan Pipeline where I work in San Jose , CA we deliver about 4 million gallons in a 24-hour period thru the pipeline.. One day is diesel the next day is jet fuel, and gasoline, regular and premium grades. We have 34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground temperature is still cold. Remember that all service stations have their storage tanks buried below ground. The colder the ground the more dense the gasoline, when it gets warmer gasoline expands, so buying in the afternoon or in the evening....your gallon is not exactly a gallon. In the petroleum business, the specific gravity and the temperature of the gasoline, diesel and jet fuel, ethanol and other petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But the service stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast mode If you look you will see that the trigger has three (3) stages: low, middle, and high. You should be pumping on low mode, thereby minimizing the vapors that are created while you are pumping. All hoses at the pump have a vapor return. If you are pumping on the fast rate, some of the liquid that goes to your tank becomes vapor. Those vapors are being sucked up and back into the underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your gas tank is HALF FULL. The reason for this is the more gas you have in your tank the less air occupying its empty space. Gasoline evaporates faster than you can imagine. Gasoline storage tanks have an internal floating roof. This roof serves as zero clearance between the gas and the atmosphere, so it minimizes the evaporation. Unlike service stations, here where I work, every truck that we load is temperature compensated so that every gallon is actually the exact amount.
Another reminder, if there is a gasoline truck pumping into the storage tanks when you stop to buy gas, DO NOT fill up; most likely the gasoline is being stirred up as the gas is being delivered, and you might pick up some of the dirt that normally settles on the bottom.
Old Apr 21, 2011 | 07:18 AM
flaharleyguy's Avatar
flaharleyguy
Makes perfect sense to me. Thanks for post
Old Apr 21, 2011 | 07:23 AM
Big-Sarge's Avatar
Big-Sarge
Great advice, I had know idea.
Old Apr 21, 2011 | 09:59 AM
lakedweller's Avatar
lakedweller
My question is does this apply to diesel also????
Edit: I see he is talking about all fuels... Coool in more ways than one...
I think this should become a Sticky
Old Apr 21, 2011 | 10:17 AM
Sgt93's Avatar
Sgt93
I have seen this before and it is great info, thanks for sharing.
kobaltblue
Jul 24, 2013 09:07 PM
DBGrif91
Mar 23, 2011 02:48 PM
Chris Gabe
Feb 2, 2009 05:05 PM
48fordcoe
Mar 28, 2008 03:19 AM
