Tranny Cooler
Old Mar 24, 2003 | 06:52 PM
chado's Avatar
chado
Tranny Cooler
Originally posted by lxman1
CK, I have added a photo of the tranny cooler on my 77 F150.
Check the 2nd 77 set of pictures in my gallery. And as far as tranny coolers go, Bigger is always better. The cooler a tranny runs, the longer it will last. Jimmy
Did you have to drill holes or anything or was their already spots for you to screw into to mount it?
CK
Old Mar 24, 2003 | 09:14 PM
Mil1ion's Avatar
Mil1ion
Tranny Cooler
Chad, You know how a zip tie works?
Imagine a zip tie with a round piece of plastic about the size of loony on one end. You slip the tie part through the vanes of the tranny cooler then through the rad and slip the keeper onto the zip tie >slide it until it's tight then snip of the extra.You do this 4 times > Done
Old Mar 24, 2003 | 10:11 PM
LxMan1's Avatar
LxMan1
Tranny Cooler
Yeah, like he said. It comes with the attatching straps that go thru the radiator and has foam pads to keep from damaging the radiator. Pretty simple install really. Just follow the directions and you should have it installed in less than an hour.
Jimmy
Old Mar 24, 2003 | 11:34 PM
chado's Avatar
chado
Tranny Cooler
good good.
You guys are great.
Now off to the bodywork forum to see if their is some tips for a guy who cant weld to fix his salty trucks cab (oh the woes of ontario) Sad thing is it was restored in 98 poorly. bah.
Anyway thats for another thread.
Thanks guys I'll pick it up when I get paid this week and tell you guys how I made out on the install + the new tranny lines I need to install. shouldn't be to hard eh? Then I can get my flush and my small block c6 should be running really nice =) Maybe I can get some better fuel milage with the new fluid (current is "burnt" as mechanic friend put it) and maybe a new fuel filter + air filter =)
CK
Old Mar 24, 2003 | 11:44 PM
Mil1ion's Avatar
Mil1ion
Tranny Cooler
Just remember that you only cut the return line to the transmission not both or the other one.
The cooler line is in series with the bottom of rad cooler tank.
Be sure to use a metal tubing cutter about 4-5" away from the connection coupler to the rad.Slide at least 3" of hose over the line & put 2 <a href="http://motorhaven.autoanything.com/">hose clamp</a>s on each end of the hose.
Old Mar 25, 2003 | 12:10 AM
Torque1st's Avatar
Torque1st
Posting Legend
Tranny Cooler
If you have a double flare tool, the first part of the double flare operation puts a nice hose retaining bump in the end of the line.
Old Mar 25, 2003 | 05:49 AM
Blaine's Avatar
Blaine
Tranny Cooler
definitely as dennis says put two clamps on (don't ask)
Old May 14, 2003 | 12:03 PM
chado's Avatar
chado
Tranny Cooler
Ok well i have the tranny cooler (got a pretty big one to) cost me 95$CAD before my discount.
Now, two questions:
Does anyone know which line will be the return line etc; for sure? Or am I going to have to disconnect and crank like instructions say?
(I have a SB c6)
And second Dennis you said to put two hose clamps on each end, and the instructions have giant warning letters saying DO NOT PUT 2 HOSE CLAMPS ON EACH END
Now I trust you, so can you tell me why to ignore these?
Thanks,
Chad
Old May 14, 2003 | 01:17 PM
Mil1ion's Avatar
Mil1ion
Tranny Cooler
Interesting !
Can you scan and send me that page?
Old May 14, 2003 | 02:40 PM
chado's Avatar
chado
Tranny Cooler
Sold the scanner, I guess I could take a picture of it with my digital camera.
As well the cardboard insert (the one that the tranny cooler rests on) also says DO NOT DOUBLE CLAMP HOSES
heh.
I'll take the picture after work. Remind me if I forget (I always check my email, so send me an email and I'll reply to it with the pictures)
Chad
Old May 14, 2003 | 03:00 PM
LxMan1's Avatar
LxMan1
Tranny Cooler
The instructions that came with mine said to do this. With the engine COLD, start it up and put it in drive for about 15 sec. Then turn it off. Feel the lines, the warm one is the supply and the cool one is the return. Worked for me.
You can double clamp as long as you do not smash the barb on the end of the fitting. I never had a problem with using one clamp, but I check all of mine about once every month or so. At least whenever I check the oil. It only takes a minute to check all of the hoses and you uasually only need a screwdriver, or you can use a 1/4" or 5/16" nut driver or 1/4" drive ratchet.
Preventive Maint. is a good thing,
Jimmy
