View Poll Results: Holley or Edelbrock Carburetor for a '78 Stock 460
Holley 64-5039
42.11%
Edelbrock 1406
52.63%
They're both pretty much the same
5.26%
Voters: 19. You may not vote on this poll
Holley or Edelbrock?????
Old 09-03-2011, 07:25 PM
lamar804's Avatar
lamar804
lamar804 is offline
I'm shopping for a new carb for my '78 F250 460. Are there any major differences in Holley vs. Edelbrock?
The two I found for my stock 460 are:
Holley 64-5039/Summit
Edelbrock 1406/Jegs
The 1406 is a little cheaper, but not enough to be the decision maker.
Thanks guys!
Old 09-03-2011, 07:31 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
If you want something that's basically "plug-n-play" right outta the box go with the Eddy, if you know how to dial in and tune a carb go with the Holley.
Old 09-03-2011, 07:46 PM
lamar804's Avatar
lamar804
lamar804 is offline
Thanks Montana_highboy!
Plug-n-play is definitely a decision maker. I've never had much luck messing with carbs in the past.
Old 09-03-2011, 08:13 PM
shooten roosters's Avatar
shooten roosters
shooten roosters is offline
i have edelbrock on my 400 now but i miss my holley yeah there is more to tune a holly but but its well worth
Old 09-03-2011, 08:19 PM
lamar804's Avatar
lamar804
lamar804 is offline
Shooten roosters why do you miss it? What's the difference in the two?
Thanks
Old 09-03-2011, 08:21 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Sw1tchfoot is offline
I say the Holley, but that's just because they are simple to me and I have never used an Edelbrock. It would be a whole new thing to learn.
Old 09-03-2011, 08:31 PM
shooten roosters
truck never ran as good after i took the holley off the only reason i like edelbrock is its better off road
Old 09-03-2011, 08:47 PM
supercabfreak's Avatar
supercabfreak
supercabfreak is offline
once the holley gets some miles on it youl be tinkering on it every weekend but to each his own, thats why i put a Q-jet on my 360 i havnt touched it since origonal setup.
Old 09-03-2011, 09:47 PM
Riderman's Avatar
Riderman
Riderman is offline
I run the eddy as well, no fussing around with it every few weeks. The only issue I have is the starting after the engine is hot. When cold, even after sitting for a few weks, just pump the pedal twice and it fires right up. After I drive it around town for a while, it has to crank for a while before it starts. I've read this is a issue with the eddy's. Do you have this problem?
Old 09-03-2011, 09:54 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Go with the Edelbrock 1406. Set it and pretty much forget it.
Keep it happy with clean fuel and filter changes.
Old 09-03-2011, 10:15 PM
lamar804's Avatar
lamar804
lamar804 is offline
Thanks guys!!! As of right now I'm leaning toward the Edelbrock 1406. Is there anything else I'll need to order with it? Adapter?
I plan to place my order in the morning. Jegs.
Old 09-03-2011, 10:21 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
You'll need the Ford kickdown adaptor if you have an automatic transmission.
Josh
Old 09-03-2011, 10:24 PM
lamar804's Avatar
lamar804
lamar804 is offline
Originally Posted by Bullitt390
You'll need the Ford kickdown adaptor is you have an automatic transmission.
Josh
Thanks Josh! I'll search for that right now
Old 09-03-2011, 10:42 PM
lamar804's Avatar
lamar804
lamar804 is offline
Ok, sorry to be a pain but as for the kickdown adapter: Is this what I need?
Edelbrock 1483 Edelbrock Carb Linkage Adapters, Studs & Cable Extensions
Thanks again!
Old 09-03-2011, 11:03 PM
Bullitt390's Avatar
Bullitt390
Thanks again!
Yep!
And ask away.. better to ask and than not too. We try to be a family here, although in a somewhat disfunctional, but somehow it works out in the end type of way.
Josh
Quick Reply: Holley or Edelbrock?????
