Sponsored by: Real Truck
Using 4wd Low for braking while towing?????
Old May 5, 2011 | 12:58 PM
  #31
Bowie's Avatar
Bowie
Originally Posted by Monster-4
You can also wire up a in cab switch and have 2WD low on-demand if you have ESOF.
https://www.ford-trucks.com/forums/9...ch-w-esof.html
Ok so I did this and put the button right next to my 4wd switch. I am assuming. when the switch is in the "on" position everything will work normal. Then when I swich it to the off position it will interrupt the signal to the unit causing the vacum pump to not come on. A little bit weird. So to get 2wd low to work I need to switch the toggle swich to off instead of on.
By the way I hooked up the switch to the pink and blue wire.
Old May 5, 2011 | 01:26 PM
  #32
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You don't want to stop the vacuum pump, you want to stop the solenoid from sending vacuum to the front hubs.
Old May 5, 2011 | 01:37 PM
  #33
Bowie's Avatar
Bowie
From what I read it is the blue and pink wire?
Old May 5, 2011 | 01:47 PM
  #34
miller_feed
I don't know. I didn't do this because I don't use 2wd low that many times a year. Let us know how it turns out.
Old May 5, 2011 | 02:22 PM
  #35
Monster-4's Avatar
Monster-4
As far as I can tell it is. I haven't done this either. Just a link I saved for when I finally install a F650 dash. This will be one of the switches I hook up.
mudslide3
Feb 13, 2015 01:48 PM
DieselJames
Oct 21, 2014 09:26 PM
00Dave
37
Oct 21, 2013 09:33 PM
black98f1504x4
Offroad & 4x4
Jun 28, 2013 04:24 PM
KJNDIVER
26
Nov 23, 2011 06:17 PM
