Sponsored by: Real Truck
Using 4wd Low for braking while towing?????
Old Apr 20, 2011 | 07:03 PM
knuckleheadnut's Avatar
knuckleheadnut
keep your speed slow, downshift, brake hard intermittently then let off, use your trailer brake controller to manually apply some trailer brake while your off the truck brake. be sure your trailer brakes are adjusted properly. NEVER let your speed build up, SLOW down.
Rick- what and where is that connector?
Old Apr 20, 2011 | 07:23 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Turning sucks in 4wd. Be easy and patient. Shouldn't have any problems at all. Not something you do want to do all the time though.
Old Apr 20, 2011 | 07:35 PM
Lubbockguy1979
Originally Posted by BlueCrystalMan
Great thread. I have sort of the same question...
I had an 03 Expedition towing a 9500 pound travel trailer. Several times over the years, we came upon steep and long downgrades. The trailer has brakes, but the Expedition just didn't want to hold it back and by the time we got to the bottom of the hill, all four wheels were smoking.
So what is the proper method for braking when towing on a major, long, sometimes twisting hill?
in my travels I usually adjust the gain on my brake controler to where when I press the brake the trailer is doing a noticable percentage of the braking. Then slow down a lot before the hill, use the transmission go to 3rd, 2nd or 1st. I always try to use everything except the brakes then you will likely have the hill beat. I used to drive 1/2 tons and I can say the superduty is a lot more pleasant to tow with both for the power and the heavier duty everything else.
Old Apr 20, 2011 | 08:02 PM
Gordon-0's Avatar
Gordon-0
this is why i love surge brakes so much.
your truck brakes barely even feel any extra load, except for the 80 or so pounds of pre-load in the brake system.
as said earlier, use your transmission as much as possible, but also remember, the brakes on these trucks are VERY stout as far as brakes go.
the rotors are much thicker than car brakes and most standard trucks.
i cant imagine that 1st gear wouldnt be enough though unless you have a really heavy trailer.
Old Apr 20, 2011 | 10:46 PM
TexasRebel's Avatar
TexasRebel
then again... if your pickup brakes have faded... the only option is a run-away ramp or a tree.
Old Apr 21, 2011 | 12:26 AM
Lubbockguy1979
and my wife thinks i drive to fast.... just practicing for either nascar or a run away situation lol
Old Apr 21, 2011 | 04:53 AM
BCM's Avatar
BCM
Unfortunately, there was no warning... and then we headed downhill. We were only doing 30 at the time, and even at 15, things heated up pretty well. My son and his buddy, both 13, thought it was the greatest thing ever.
Is there any rule of thumb for winding out the gears before switching?
Old Apr 21, 2011 | 08:09 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If you look at the pic, you will see the passenger side negative battery post. It is on the firewall close to the battery. It's what sends the signal and vacuum pulse to the hubs to lock and unlock. With this unplugged, no signal/vacuum will go to the hubs. I disconnect this when I have to back my trailer on soft ground. It's also easier on the transmission when backing using low.
Old Apr 21, 2011 | 09:42 AM
knuckleheadnut
Rick- great tip. thanks for the reply!
Old Apr 21, 2011 | 10:07 AM
Lubbockguy1979
Most of the time the tranny will not go into a gear if the vehicle is moving to fast and will up shift. Me personally I have gotten in the habit of using the tow haul to stop and then turn it off. My old chevy work truck (08) had the allison and I could tap the brake and it would down shift which was super nice. Probably the only thing good to say about that truck though.
Old Apr 21, 2011 | 10:58 AM
Bowie's Avatar
Bowie
Originally Posted by miller_feed
If you have ESOF, unplug this little guy and it will not send a signal to lock the front hubs. Then you will still have low with 2wd.
Is it the tan colored unit I need to unplug? Having trouble making what I am suppose to unplug?
Old Apr 21, 2011 | 11:22 AM
bpounds's Avatar
bpounds
Here is little better photo.
Old Apr 21, 2011 | 11:27 AM
  #28
miller_feed
Yes.
Thanks Bill. That is a lot better pic. I need to get a better pic of that little thing. lol
Old Apr 21, 2011 | 01:50 PM
  #29
Bowie's Avatar
Bowie
Hey reps to both of you I had no idea of what that unit did. Thanks
Old Apr 21, 2011 | 02:22 PM
  #30
Monster-4's Avatar
Monster-4
You can also wire up a in cab switch and have 2WD low on-demand if you have ESOF.
https://www.ford-trucks.com/forums/9...ch-w-esof.html
