Great truck, great rig and wow, how about that backyard! Congratulations, it just gets better here on out. I like the fact you weighed everything, something I still need to do. Yet, pulling our Raptor toyhauler with the Ride Rite Air bags can't be beat.
yes, add the two axle weights (5140 front and 6520 rear) and my truck weighs 11,660 with the 5er hooked up to it.
And about my back yard, I rented a Bobcat and made a level place that is just an extension to my driveway so it's kinda the back/side yard area. All I have to do is back in from the road and keep going past the garage to my extension. A bundle of railroad ties and about 8 yards of gravel and we have a nice place to keep the camper.
I appreciate the kudos, it was a solid 2 days of work and I am proud of it.
Towing the 5er compared to the bumper pull 28 footer I had is no comparison. Yes, things are heavy, heavier than my old camper for sure, but the ride quality is amazing, the stability is fantastic. I have experience towing 5er's for work so the turning radius and difference in going backwards are no surprise to me.
Also, I have always gotten by without a slider hitch but I'm glad I have one now. It does come in handy.
Scott: Yes, moving the hose is a pain. I take it you customized the plumbing under the camper to make it all come out the rear? Good idea.....
On board air, great thing to have along with the reservoir tank. You can change the ride on the fly, go around and top off the tires.
When you get good at using the airbags, you can leave your trailer tongue at the lowest point where your airbags are deflated, then back up to it, inflate the air bags, and get by with almost no use of the tongue jack. Fine tuning your ride height or ride quality while you drive is a breeze.
There have been times on hills or funny changes of terrain where I needed extra height for the hitch to clear the ground without bottoming out, just pump the bags up.
Also, there have been times when I need the rear of a trailer to be higher, so I deflate the bags in order for it to not bottom out in the rear.
Rusche - good description on using the airbags while hitching/unhitching. I do the same thing with the fifth wheel. While extending the landing gear, I deflate the airbags at the same time an vice-versa for hooking up. Saves about a minute or so of standing there with my fingers on the landing gear rocker switches. It's cool to have two separate systems working together like that.
Little off topic....... You guys with air bags, do you have on board air or manually pump up the bags before hitting the road.
When I had air bags in the GMC I used an Airlift wireless controller. Worked great. I am currently installing this kit in the Trailer Saver hitch for the same convenience.
