Clutch cable broke?
Old Apr 21, 2011 | 11:18 AM
thechief66's Avatar
thechief66
It looks like you also need to replace the post on the clutch pedal assembly that the master cylinder attaches to. It's Ford # E7TZ-7A554-A, about $25.
Usually what happens is the little bushing in there wears out, then it starts wearing down the little stud and the pushrod till one or the other breaks.
Old Apr 21, 2011 | 11:24 AM
BRay09's Avatar
BRay09
The push rod usually comes with a new master cylinder
Old Apr 21, 2011 | 03:46 PM
MFogarty1996's Avatar
MFogarty1996
Originally Posted by BRay09
Or if you have 2 helpers you can put everything on and get a rubber vacuum line that can connect to the bleeder on the slave. Use a clean clear container and put the brake fluid in it. Insert the vacuum line in the container and have one person continue to fill the reservoir while the other pumps the pedal. Do this until the air bubbles quit coming out.
Best advice i got! But all the others helped as well. After my brother and father helped me it took about 5 mis to do it. The replacements included push rod and master cylinder. the little stud that connects to the clutch pedal was fine the new plastic piece clicked on and has no play other than what is needed to move. Everyone was a Great help. i love this site for that exact reason. Thanks guys!
Old Apr 22, 2011 | 12:04 PM
BRay09's Avatar
BRay09
Glad we could be a help. I thought that was the easiest way i found to get no air in the line or slave. Works the best and helps with spongy clutch feeling.
Do i feel some rep points for that post
Old Apr 22, 2011 | 04:40 PM
thechief66's Avatar
thechief66
I wasn't referring to the pushrod, I meant the part that hooks into it.
But it sounds like he got it together OK.
Old Apr 22, 2011 | 04:53 PM
BRay09's Avatar
BRay09
Oh. I didnt know that you could even replace that part!
Just for reference, they usually have those plastic pieces that hold the plunger on the peddal in the Help! isle at advanced auto parts. Could never locate them when i had my old truck. It always kept breaking them off
Eddillard79
Jun 13, 2015 03:07 PM
sonny1965
Jun 8, 2014 05:33 AM
RacerLT250R
Jul 5, 2012 09:46 AM
ChristopherN
15
Jun 9, 2011 08:10 AM
Eaglefixer
1983 - 2012 Ranger & B-Series
Nov 30, 2009 12:24 PM
