axel question
Old Apr 19, 2011 | 07:52 PM
finneys98xj's Avatar
finneys98xj
axel question
I am looking at buying a 78 f 150 4x4 will a rear end out of a 72 f250 2wd swap in with out any mods?
Old Apr 19, 2011 | 08:06 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The rear in the F150 is probably a Ford 9", although it could be a Dana 44 but that's rare. The F250 is going to be a Dana 60 so I'd say there's going to be some mods.
Old Apr 19, 2011 | 08:11 PM
finneys98xj
The question I should have asked is. Are the leaf perches the same distance apart on both axeels.
Old Apr 19, 2011 | 08:54 PM
justforkicks's Avatar
justforkicks
if i remember correctly, the frames on pre 1977 f250's were narrower in the rear (please, correct me if i'm wrong). i don't think the perches are the same distance.
i know they changed the frame width so you could have a rear gas tank in it but i don't know if it was a big change in width or not.
could always bust out the tape measure and measure the distance between the leaf packs on both trucks
Old Apr 22, 2011 | 10:18 PM
4bysnduallies's Avatar
4bysnduallies
you could weld on new spring perches where you need them,but check axel ratio's first
