A/C blows Fuse at accelaration
Old Apr 19, 2011 | 03:37 PM
gfamultra's Avatar
gfamultra
I have a 2000 Ford Excursion, V10 Triton engine, that just started blowing fuses when I accelerate. Checked to ensure that I had freon, pressure is normal. When idling it the fuse will not blow, but as soon as I accelerate it blows the #24 fuse (10 amp). Anyone have any ideas? At my end trying to track it down
Old May 10, 2011 | 06:45 PM
XNrepair's Avatar
XNrepair
I have an 03 6.0 Diesel and it is doing the exact same thing ! I change the fuse and it works until I drive it.... Did you ever get the issue fixed ? I'll keep looking and let you know if you can do the same !
Old May 10, 2011 | 10:17 PM
gfamultra's Avatar
gfamultra
No have not found an issue for it, trying to trace it down and think that it is a ground somewhere, might be also the compressor might be bad and needs replacing but if i find anything out I will let you know as well
Stuck in germany
Jun 19, 2022 11:43 PM
cokehauler
Electrical Systems/Wiring
Jul 29, 2016 11:29 AM
Michael Warnick
Jun 6, 2016 11:59 AM
SMUNIGA
Apr 17, 2015 04:03 PM
NTENSE
Sep 22, 2014 01:23 PM
