need help
Old Apr 19, 2011 | 12:16 PM
shane dalhaus's Avatar
shane dalhaus
need help
i have a f150 that i just put a engine in and i changed everthing out off the old engine except the flywheel, but now when its ideling it has a vibrration to it could it be that i need to put the old flywheel back on?
Old Apr 19, 2011 | 03:21 PM
f100jim's Avatar
f100jim
What engine?
There are differences in flywheel balance between engines, and even within an engine line depending on date of manufacturer.
A vibration at idle can also be caused by other things, like misfiring, running way too rich, etc.
Old Apr 19, 2011 | 09:57 PM
shane dalhaus
i put a 302 in it same as the one that was in it only diffrence was the flywheel that was on the motor that came in the truck has a balance weight on it and the new engine the flywheel doesnt have a weight thats why im thinking its the flywheel that needs to be changed because its balanced with the tourc converter im guessing! the motor not misfireing and the motor mounts are fine thats all thats left i just need a second app.
Old Apr 20, 2011 | 01:26 AM
cj06's Avatar
cj06
you just answered your own question ! check the front harmonic balancer !
