just bought a 6.0L OIL LEAKS PLEASE HELP!
Old 04-18-2011, 10:17 PM
'94Nichols's Avatar
'94Nichols
'94Nichols is offline
I just bought an '06 f.250 ex cab 4x4 with a 6.0L. I have noticed an oil leak on the front, drivers side and the rear, passenger side of the engine, there is also some oil on the bottom of the bell housing. none of them look realy bad, but i don't want my truck leaking. any ideas? should i be worried? I am like alot of people in that ive heard ALOT of bad about the 6.0L, but i have a friend who is very happy with his '03. also, is an egr delete kit necesary on this year 6.0L?
Old 04-18-2011, 10:51 PM
Litigator's Avatar
Litigator
Litigator is offline
It's going to be a cab off repair. I had this on my 06 and it was covered under warranty. $4000+ repair at the dealer.
Old 04-18-2011, 11:19 PM
Tennesseepowerstroke's Avatar
Tennesseepowerstroke is offline
You can buy a good drip pan and a lot of oil for $4000.
Seriously, it could be coming from several different areas. It could be a $40 repair. Clean the oil off and see if you can find where it is leaking from.
Old 04-19-2011, 04:43 AM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Moved to the 6.0L Powerstroke Diesel forum.
Old 04-19-2011, 06:10 AM
bismic's Avatar
bismic
bismic is online now
Received 2,543 Likes on 1,771 Posts
You need to look over our Tech Folder:
https://www.ford-trucks.com/forums/3...ch-folder.html
Specifically here:
https://www.ford-trucks.com/forums/8...att66f100.html
The leaks can be from MANY places (unfortunately), but to be able to say you have to remove the cab by reading only a single post on oil leaks from you is way off base. I hate oil leaks also (have a little drip hanging, not dropping, from the bell housing). Even if it IS a bed plate leak, NO WAY would I have the engine removed just to fix it.
Do what Tennesseepowerstroke said. You can even go to the dealership and have them put some dye in the oil. I have read that you can buy the dye yourself, but have never researched it. Either way, clean the engine area. There was a recent post on that. Then decide what next.
Old 04-19-2011, 06:12 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
Very well said. They're more annoying than serious unless it's leaving puddles.
Old 04-19-2011, 06:41 AM
Will Bite's Avatar
Will Bite
Will Bite is offline
My 06 did that to out of bell housing. bed plate seal under warranty.
Old 04-19-2011, 08:49 PM
'94Nichols's Avatar
'94Nichols
its still under my 30 day warranty, which is 50/50 (I pay/they pay) im gonna see what they want to fix it. i went to a diesel shop today and a mechanic told me an injector is going out. im thinkn about just payin half and making them fix everything, but if i understand correctly, oil leaks arent a pig deal?
andy33040
10-15-2016 06:21 PM
Rmblanchard02
08-08-2016 09:45 PM
Firefighter739
08-02-2016 10:29 PM
popupJunky
27
01-21-2012 05:50 PM
bfnavarrete
1999 to 2016 Super Duty
11-05-2010 09:39 PM
Quick Reply: just bought a 6.0L OIL LEAKS PLEASE HELP!
