Sway Bar Install
Old Apr 18, 2011 | 09:54 PM
rebelmdb's Avatar
rebelmdb
Sway Bar Install
Well my links keep popping off so upon further inspection have determined the sway bar is jacked. Anyway got one ordered and will install it this weekend. Anybody got any tips or suggestions on other things to replace while I'm down there? Put new links on today while I had it up on the lift. It doesn't look like it should be too hard but then again who knows right.
Old Apr 18, 2011 | 10:12 PM
nitro3421's Avatar
nitro3421
If you've already done end links youve done the harder part. I would also replace the bushings while you're in there. It's all pretty easy luckily.
Old Apr 18, 2011 | 11:23 PM
big poppa's Avatar
big poppa
X2, very simple bolt on install.
Old Apr 19, 2011 | 06:01 AM
comadvan's Avatar
comadvan
Are there different size sway bars?
Old Apr 19, 2011 | 08:58 AM
PwerStroke99's Avatar
PwerStroke99
U ordered the whole sway bar? You could have bought just the bushing from Clay at RiffRaff for under $40. Mine was doing the same thing, replaced the bushings and all is good now. Easy job
Old Apr 19, 2011 | 01:49 PM
Phrosut's Avatar
Phrosut
Yes, many different sizes and not a huge difference between the close sizes. Before ordering bushings you should measure the diameter with a micrometer because using rulers or tape measurements won't get an exact enough measurement.
Phil
Old Apr 19, 2011 | 02:38 PM
Tailgate77478's Avatar
Tailgate77478
Yes, there are different sizes from Ford (thickness of the sway bar) and other aftermarket companies. I bought a Hellwig swaybar for my Excursion, and it's been great.
Old Apr 19, 2011 | 06:09 PM
rebelmdb's Avatar
rebelmdb
Yea I ordered the whole bar. Mine is twisted from what I can tell. Sounds like an easy swap so should make for a fast Sat.
Old Apr 19, 2011 | 06:15 PM
Phrosut's Avatar
Phrosut
WOW that must've taken one big hit. Those bars are made to twist and flex like a spring because that's what they function as.
Was the truck ever in a serious accident? I can't envision much else that can damage the sway bar. I've never seen it and I worked in a brake and front end shop for a decade.
Phil
Old Apr 19, 2011 | 06:42 PM
big poppa's Avatar
big poppa
I came pretty close bending mine in the snow when my one tire went into a ditch off the road trying to avoid kissing another trucks mirror, had all kinds of grass and mud was caked in the middle of it. Hopefully no rocks were hit but it could have happened and going maybe 20-25 MPH I believe it can and will bend that swaybar if enough force is banged into it...
Old Apr 19, 2011 | 06:44 PM
429 f-100's Avatar
429 f-100
ive changed a bunch over my collision career maybe 25 usually not twisted though bent .
JeffHann74
Apr 15, 2011 06:27 PM
Jessef250
Dec 10, 2010 07:39 PM
93F250
Aug 13, 2007 07:04 PM
