$70 electric fan system
Old Apr 18, 2011 | 09:43 PM
F-250 restorer's Avatar
F-250 restorer
If you'd like to read about how to make an electric fan system for $70 (3400 cfm), then ck out my new article in True Blue Trucks magazine.
It's easy as pie.
Cheers.
Old Apr 18, 2011 | 11:20 PM
pidaster's Avatar
pidaster
It's easy as pie.
Cheers.
Don't get the magazine.
Link perhaps?
Old Apr 19, 2011 | 03:03 AM
mudder460's Avatar
mudder460
I myself would like to know this but I'm currently deployed right now and limited on what the sell here. A link or something would be great cause I'm looking to do this when I get back.
Old Apr 19, 2011 | 12:41 PM
F-250 restorer
You can either download the article from THE Ford-only Truck magazine, True Blue Trucks features all Ford trucks, classic, new, rusty, shiny, gas, diesel, toys, workers, street rods, 4x4 off road, or read one of my posts: Taurus fan install, or dual Contour fan.
Basically, there are two routes you can go, the two speed Taurus fan/Mk v111 fan, or the dual Contour fan. The Taurus/mk8 fan will be initially less expensive from a j/y, about $35, whereas the dual Contour fan cost more for the extra motor. The Taurus fan puts out about 2300 cfm low, and about 3800 cfm on high. The mk 8 fan pulls a bit more. The Contour fan pulls 3400 cfm.
Where the cost of the T/mk8 fans increase is when you have wire them. Because they pull so many amps, you have to buy a heavy duty relay/solenoid for the high sp. That can fun $50 alone.
If you have room, I would use the Taurus or mk8 fan. If you want to keep the cost down, use the Contour dual set up. Wire them like I did and if one dies, you can still 'limp' home w/o overheating. Or, pull an extra motor at the boneyard and keep it behind the seat in case.
Old Apr 19, 2011 | 01:06 PM
mudder460's Avatar
mudder460
Great thanks! I have your thread saved already so I can referance it once I get back home. I might use the Contour fan, I like the "limp home" mode. Soooooo many plans for my truck when I get outta here! lol
