Rear window motor and signal switch
So I have been working on my daughter's 86 XLT. I have to replace the gear set for the rear window motor. I see how to remove the lift arms and the motor, but my question is the rear glass. I see two "Brackets" that are attached to the bottom of the glass. Each side has 2 bolts and 2 rivets. Should I grind the rivets off then replace with bolts or is there another method to remove the glass to get to the motor?
I also have ordered a replacement turn signal switch. I take it removing the steering wheel is the way to get to the switch.
Thanks all!
Thanks all!
Well now that I know that...I will go ahead and remove those rivets and replace with nuts-n-bolts. I was lucky on my first Bronco in the family that the only thing I had to fix for the rear window was the wiring next to the tailgate.
Spktyr
03-17-2013 12:46 AM
ed2hess
23
01-07-2011 02:08 AM
Charger73400
1983 - 2012 Ranger & B-Series
12-30-2005 10:31 PM
