Sponsored by: Real Truck
Trailer Brake Controller Plug
Old Apr 18, 2011 | 05:40 PM
Pollack Pete's Avatar
Pollack Pete
I've got a 2006 F-350 Super Duty.I bought it last November.I'm getting ready for my first road trip with my 2 axle flat trailer.My question.....where did Ford hide the 6 pin plug for the trailer brake controller under the dash ?I've looked just about every where and I can't find it.I had a 97 F-150 before I got this SD and the plug was easy to find.It was right near the OBD plug.Please steer me in the direction of this elusive plug.Thanks for any and all help.
Old Apr 18, 2011 | 05:50 PM
rattleNsmoke's Avatar
rattleNsmoke
Hi Pete,
On my '06 SD, I grabbed the cubby hole liner where the factory tow command goes, with small vise grips and pulled it out (with some force). It popped right out and the brake controller plug was right there in a dummy socket. Piece of cake. If you want ideas where to position the brake controller, let me know.
Old Apr 19, 2011 | 02:53 PM
Pollack Pete
Can't Find It
Well,I popped the plastic blank cover off the dash today.No plug behind the cover.Unless I'm looking in the wrong cover plate......it is the approx. 3 inch square cover plate to the right of the steering column,right?Anybody got any more ideas where that trailer controller plug might be?? Thanks in advance.
Old Apr 19, 2011 | 09:14 PM
jh818's Avatar
jh818
It's about 1" x 3/4" rectangular.
Old Apr 19, 2011 | 09:52 PM
DPorter's Avatar
DPorter
below radio to the right of fuse panel panel by steel support.
Old Apr 20, 2011 | 06:58 AM
rattleNsmoke
You have to remove the cubby hole where the tow command and upfitter switches normally reside. It's that black alcove approx 6" wide by 2" tall?
Old Apr 20, 2011 | 10:48 AM
bpounds's Avatar
bpounds
This might help.
https://www.fleet.ford.com/truckbbas/non-html/Q119.pdf
contento
All Things Towing
Jun 7, 2014 07:16 AM
Crazyotto1
Dec 28, 2013 09:08 AM
bigsbetter11
May 22, 2013 07:04 AM
glovemeister
26
Mar 13, 2012 08:21 PM
FordTrucksKickGM
All Things Towing
Jan 9, 2008 03:25 PM
