Ford Part # for engine wiring harness
I have the lighting harnesses and the dash to gauge harness, with the generator to Voltage regulator wires, I can make the distributor to coil wire if need be. But It seems I am missing a couple harnesses, and I can't read/identify the part#'s from the catalog/CD I have. Seems like I need the harness to the Voltage regulator, and the one to-from the solenoid. Any Ideas out there?
I have the lighting harnesses and the dash to gauge harness, with the generator to Voltage regulator wires, I can make the distributor to coil 12216 primary wire if need be.
But it seems I am missing a couple harnesses, and I can't read/identify the part#'s from the catalog/CD I have.
Seems like I need the 14305 harness-generator to the Voltage regulator, and 14398 to-from the solenoid.
gangstakr
03-14-2015 01:28 PM
Pitcrw6
08-26-2012 12:59 PM
