Bad Fuel Pump?
Old Apr 17, 2011 | 10:41 PM
StevensPoint's Avatar
StevensPoint
Bad Fuel Pump?
Hi All-
It's happened a few times now where I start the truck and it sounds funny - real quiet and a puff of black smoke. The first time it happened I took off and it seemed OK for about a block then lost all power. I looked down at the fuel pressure gauge and it read 0 psi. Just then it jumped to 50 psi, regained power and all was well. No problems after that.
A few weeks later I noticed the real quiet start again. I stayed idling and just watched the fuel pressure gauge at 0 psi. After a little bit it jumped to 50 psi and stayed.
I'm assuming fuel pump, but is there anything else I should look at first?
Thanks for the help.
Old Apr 18, 2011 | 12:55 AM
brickie's Avatar
brickie
New fuel pump.
Old Apr 18, 2011 | 01:09 PM
StevensPoint
If the fuel pump covered under the 100K warranty?
Thanks
Old Apr 18, 2011 | 01:22 PM
lenzhotrod's Avatar
lenzhotrod
Try turning the key on twice before starting to get your pressure up.
Old Apr 18, 2011 | 02:13 PM
william_04_x's Avatar
william_04_x
Thanks
If you have a Ford ESP, it can be, depending on which one you purchased. A Premium Care covers just about everything.
Whether it's covered or not, this is something you should get taken care of ASAP.
barnbridge
Apr 12, 2013 02:57 PM
mvvette97
Dec 1, 2008 10:51 AM
bigred66
1978 - 1996 Big Bronco
Oct 5, 2007 12:16 PM
dvldog458
Jan 19, 2006 01:10 PM
cougardude70
Oct 10, 2003 11:40 PM
