1978 - 1996 Big Bronco
Vent Window Leak
Old Mar 19, 2003 | 09:46 PM
mweeps's Avatar
mweeps
Vent Window Leak
What would be the best thing to use to fix a leak in my Vent Window? It leaks between the frame and the glass.
Old Mar 19, 2003 | 10:18 PM
steve83's Avatar
steve83
Vent Window Leak
Between which frame & which glass? The straight divider & the door glass; the divider & the vent glass; or the forward vent frame & the vent glass? Are you sure it's leaking at the glass? Usually, it's between the vent frame & the rubber seal at the bottom near the pivot.
Old Mar 19, 2003 | 10:43 PM
mweeps's Avatar
mweeps
Vent Window Leak
Vent glass and the frame that goes down the front edge and along the bottom of the glass. Went through a carwash and can watch it come from under the glass. The seal is gone between the frame and glass.
Old Mar 19, 2003 | 11:34 PM
steve83's Avatar
steve83
Vent Window Leak
Pull the glass out of the frame, clean both, & put it back with black silicone or polyurethane adhesive. Don't try to clean up what squeezes out until it's THOROUGHLY dry.
Old Mar 20, 2003 | 10:30 AM
mweeps's Avatar
mweeps
Vent Window Leak
Steve83 will I have to pull the whole thing out or just open window and pull out the glass from the frame? I might take it somewhere and have it done and get weatherstipping around the frame replaced. The weatherstrip is $95 from Ford.
Old Mar 20, 2003 | 05:36 PM
steve83's Avatar
steve83
Vent Window Leak
A complete vent window assembly from a junkyard is only $10-80, depending on year. What's yours? (Fill in your profile! )
If the sealant is so bad that it leaks, you should be able to work the glass out just by opening the window. But if the rubber is bad, you might as well replace the whole thing.
Old Mar 20, 2003 | 11:19 PM
mweeps's Avatar
mweeps
Vent Window Leak
Steve83 it is a 96 XLT Sport. Junkyards around here don't have crap.
Old Mar 22, 2003 | 01:22 AM
steve83's Avatar
steve83
Vent Window Leak
OK So you've got the $80 vent window. '92-96 will fit.
Old Mar 22, 2003 | 01:00 PM
bronco cam's Avatar
bronco cam
Vent Window Leak
Hey remember ford pickups from 92-96 will also have the right vent window. You can pull one from the trucks. I got one from the junk yard for 30 bucks out of a 96 f150 for my bronco..
